TELEGARTNER MFP8 T568A Connector RJ45 Ethernet High-End Metal
Easy to install RJ45 connector (no tool required). Shield 360 ° C; great connectivity.
Reference : 12726
14,90 €tax incl.
12,42 € tax excl.
RJ45 connector high quality by TELEGARTNER
These RJ45 connectors T568A are among the best in the market with a metal body, a high performance shielding and ease-of-use.
Used in conjunction with a Viablue EP-7 cable, enables the design of high quality interconnects
Here is a link concerning the T568A and T568B standards which will allow you to make the right choices for your network installation: T568A vs T568B
Tool-free assemblyYes (+ 360 ° C)
total shieldYes (+ 360 ° C)
StandardISO / IEC 11801
Maximum diameter driversStranded 0.51 - 0.64 mm (AWG 24-22)Multipbrins 0.46 - 0.76 mm (AWG 27-22 / 7)
Temperature of use-40 to 70 ° C
PoE +High Power over Ethernet (PoE +) IEEE 802.3at
BodyZync plated nickel and diecast
standard colorT568A
Max cable diameter (mm)N/A
Mounting typeTo connect
ConnecticMale
ConnectorRJ45
Contacts Plating (Connector)N/A
Trés bon connecteur
Très bien conçu, très bon guidage des fils!
Et meme mieux: le connecteur se relie au blindage du câble, ce qui permet de conserver la continuité du blindage.
Attention: il y a un modèle T568A et T568B, et il ne sont pas permutable grâce (ou à cause) d'un mécanisme de détrompeur.
Je le recommande...
This review has been posted for TELEGARTNER MFP8 T568A Connector RJ45 Ethernet High-End Metal
