The T6s-RJ45 CAT6 high-end CAT6 network plug is distinguished by a finish and quality of contact rarely achieved in the world of computing. Its scratch-resistant ULTRAGRIP design offers a satin finish of the most neat.
This high-level RJ54 socket is ideal for high reliability network design as well as cable design I2S RJ45 AUDIO, DSD DXD, 32bitfor DACAUDIO GD, PS AUDIO, Audiophonics interfaces, M2TECH.
Its precision machining with guide plates for the 8 CAT6 wires allows for fast and high quality contact positioning. This RJ45 network socket is compatible with professional type crimping clamps 8P8C.
Its fixing system with 6 x 1.5 mm double screw ensures long-term reliable mechanical maintenance for cables with a large section up to 10 mm in diameter.
The polycarbonate outer body of this high-end RJ45 CAT6 plug features a flame retardant and a high resistance to the most common shocks.
the majority of metal parts have benefited from plating Gold 24k.
This plating present over the entire surface of the contactst more resistant and better conductor than standard gold plating, against any form of oxidation. The electrical behavior of the characteristics is therefore maintained even after many years of operation.
An assembly manual is available for download.
Specifications:
- Plated contacts 24K Gold
- RJ45 plugs 8 Crimp contacts
- Maximum cable diameter acceptable: of 7 mm to 10 mm
- Viablue surface ULTRAGRIP scratch resistant
- Double clamping cable with high maintenance on screw 6 pan of 1.5mm
- 8-wire high-speed CAT6 guide plate
- Compatible with collet 8P8C
Dimensions:
- Overall Length: 51.5 mm
- Max width of the plug 14.4mm
- Max Height of Cap 18.5mm
Sold in pairs.
VIABLUE T6s RJ45 Plated OR 24K
