This 20-position rotary encoder has a notched shaft for attaching a button and a push button. In particular, it can be used as volume and source control.
20 steps, push button, notched shaft 20mm
This 20-position incremental rotary encoder has a notched shaft to attach a knob. It can be used as a volume control or to adjust the level of audio, video or computer devices with a suitable programming chip (not supplied). The encoder also acts as a push button and can therefore also be used as a source selector for example..
Type of product | Rotary digital encoder + push button |
Number of steps | 20 |
Shaft type | Notched shaft |
Output | Incremental |
Shaft length | 20mm |
Shaft diameter | 6mm |
Total dimensions | 15 x 12.5 x 30mm |
Type of connection | Pins to solder |
