Rotary Digital Encoder 24 Steps Push Button Notched Shaft 15mm
This 24-position rotary encoder has a notched shaft for attaching a button and a push button. In particular, it can be used as volume and source control.
Reference : 13023
1,60 €tax incl.
1,33 € tax excl.
Shipping date: 29-04-2025.
Rotary encoder
24 steps, push button, notched shaft 15mm
This 24-position incremental rotary encoder has a notched shaft to attach a knob. It can be used as a volume control or to adjust the level of audio, video or computer devices with a suitable programming chip (not supplied). The encoder also acts as a push button and can therefore also be used as a source selector for example.
Type of productRotary digital encoder + push button
Number of steps24
Shaft typeNotched shaft
OutputIncremental
Shaft length15mm
Shaft diameter6mm
Total dimensions15 x 12.5 x 25mm
Type of connectionPins to solder
encodeur rotatif axe méplat 15mm
ShaftNotched
ChannelN/A
Resistance (Ohm)N/A
Tolerance (%)N/A
This 24-position rotary encoder has a notched shaft for attaching a button and a push button. In particular, it can be used as volume and source...
