Rubber Damping Feet Ø16x8mm Transparent (Set x4)
These shock absorbing rubber feet with a diameter of 16mm and a height of 8mm are simply glued under your devices using the double-sided 3M supplied to give them better stability and limit vibrations.
Reference : 14345
1,50 €tax incl.
1,25 € tax excl.
Shipping date: 16-09-2026.
Rubber damping feet
Ø16x8mm (x4)
Pieds caoutchouc amortissant Ø16x8mm (Set x4)
Product typeDamping feet
MaterialRubber
Diameter16mm
Height8mm
ColorTransparent
QuantitySold by 4 feet
Diameter (mm)16.0
MaterialRubber
Height8.0
3 reviews
Excellent for small components
Very good for small stuf.I am using them in my VMV D1SE DAC replacing the annoying factory spikes.It does the job.
This review has been posted for Rubber Damping Feet Ø16x8mm Transparent (Set x4)
Pieds pas chers et efficaces
Je recommande ces pieds, en particulier sous des lecteurs cd, lesquels peuvent parfois apparaître agressifs avec des pointes.
Ces pieds sont trés efficaces alors...
Do what they're supposed to.
Not much to say. They're firm plastic feet that are easily glued to your device of choice.
These shock absorbing rubber feet with a diameter of 16mm and a height of 8mm are simply glued under your devices using the double-sided 3M...
