Rubber Damping Feet Ø8x2mm Transparent (Set x10)
These rubber damping feet, Ø8mm in diameter and 2mm high, are simply glued to the underside of your equipment using the supplied 3M double-sided adhesive tape, to give it greater stability and reduce vibrations.
Reference : 18197
0,70 €tax incl.
0,58 € tax excl.
Shipping date: 29-04-2025.
Rubber Damping Feet
Rubber Damping Feet Ø8x2mm Transparent (Set x4)
Technical characterics
Product typeDamping feet
MaterialRubber
DiameterØ8mm
Height2mm
Mounting3M
ColorTransparent
PackageSet x10
Diameter (mm)8.0
MaterialRubber
Height2.0
These rubber damping feet, Ø8mm in diameter and 2mm high, are simply glued to the underside of your equipment using the supplied 3M...
