Aluminium wall plate Schuko Double socket for FURUTECH FI-E30 Silver
We designed this all-aluminium wall plate to cover the Furutech plugs FI-E-30 (G) and FI-E-30 (R) and thus transform it into a complete wall socket.
Reference : 17795
19,90 €tax incl.
16,58 € tax excl.
Wall plate
Aluminium plate for Schuko double Furutech plug FI-E30 Silver
The centre distance of the fixing screws is compatible with wall socket boxes. Screws are sold separately.
Caution: Not all subbases are compatible with this plate. Please select the subbase models mentioned above.
ColorSilver
Thickness8mm
MaterialMassive Aluminium
Holes spacing for flush-mounted box60 x 72mm
Dimensions84 x 150mm
Screws sold separatelySubbase fixation screws : 4x M4x6mm
Wall plate fixation screws : 2x M3 x 20mm
Furutech base to buy separatelyFI-E-30 (G) or FI-E30 (R)
Illustration with a Furutech FI-E30 (R)
(sold separately)
Max cable diameter (mm)N/A
Mounting typeN/A
ConnecticN/A
ConnectorN/A
Contacts Plating (Connector)N/A
Very high quality / très bonne qualité
Beautifully made. It is slightly larger (155 mm) which is mote than I could wish for, it has a perfect fit on the PEHA Standard surface-mounted frame, like the two were made for each other.
/ Magnifiquement fait. Il est légèrement plus grand (155 mm), ce qui est bien plus que ce que je pourrais souhaiter, il s'adapte parfaitement au cadre en saillie PEHA Standard, comme si les deux étaient faits l'un pour l'autre.
This review has been posted for Aluminium wall plate Schuko Double socket for FURUTECH FI-E30 Silver
