FURUTECH FT-SDS (G) Power Plug Schuko Type F for Power Distributor Gold Plated
This Schuko Furutech FT-SDS(G) sub-base is intended for installation in a power distributor. The high quality pure copper contacts with gold plating ensure excellent electrical signal conductivity.
Reference : 2935
74,00 €tax incl.
61,67 € tax excl.
Shipping date: 16-04-2025.
Furutech FT-SDS (G)
Schuko Socket for Power Distributor Gold Plated
Furutech FT-SDS (G) Prise Schuko pour Distributeur Secteur Plaqué Or
This Schuko Furutech FT-SDS(G) sub-base is intended for installation in a power distributor. The high quality pure copper contacts with gold plating ensure excellent electrical signal conductivity. The body of the base is made of Nylon and fiberglass.
The depth of the grip is 52mm. This will not be suitable for all installations.
Product typeSchuko plug for power distributor
Contacts materialPure Copper
Furutech α (Alpha) treatment
Body materialNylon
Fiberglass
Front panel materialPolycarbonate
Base materialZinc / Steel 1mm
Max cable diameterØ2.8mm
Max cable section5.5mm² (10AWG)
Dimensions54.8 x 54.8 x 52mm
Cutout diameterØ55mm
Voltage / Current250VAC 16A
Mounting holes spacing40 x 40mm
Cutout for the passage of the bottom plate50 x 50mm
Max cable diameter (mm)2.8
Mounting typeTo screw
ConnecticFemale
ConnectorType F (CEE 7/3 - CEE 7/4)
Rated current (A)16.0
significant change
SQ has significantly changed in comparison with an older wall socket. Base got deeper and mid top region got the second dimension. Fully satisfied with purchase. Big thanks to Vlad form Unison audio saloon in Riga Latvia for installing this socket!
This review has been posted for FURUTECH FT-SDS (G) Power Plug Schuko Type F for Power Distributor Gold Plated
This Schuko Furutech FT-SDS(G) sub-base is intended for installation in a power distributor. The high quality pure copper contacts with gold...
