By buying this product you get 27 loyalty points
Schuko Socket for Power Distributor Rhodium Plated
The Rhodium-plated Schuko Furutech FT-SDS-R NCF plug is a new version with a body using the brand's technological advances. Taking up the recognized qualities of the technical developments of Furutech "Piezo Effect" ceramics with damping properties, here is a very high level mains socket.
As for the other Schuko plugs of the Japanese brand, this one receives the patented Alpha non-magnetic treatment which made the reputation of Furutech. The high contact quality of this high-end plug makes it an indispensable accessory for high-end hi-fi systems requiring the utmost attention to detail.
In addition, this plug is Rhodium-plated for high stability over time of the mechanical and electrical characteristics of this Furutech wall outlet.
Incorporated in the new Furutech product series, NCF (Nano Crystal² Formula) consists of a special crystalline material with two "active" properties.
First of all, it generates negative ions that eliminate static electricity. It also converts thermal energy into far infrared (LIR) energy with wavelengths ranging from 50µm to 5mm.
Furutech then combines this remarkable material with nanoscale ceramic particles and Carbon powder for their "piezo effect" (damping properties).
The resulting Nano Crystal² (NCF) formula is the ultimate electrical and mechanical damping material and is only available in Furutech products.
The depth of the grip is 52mm. This will not be suitable for all installations.
Product type | Schuko socket for power distributor |
Contacts material | Pure Copper Furutech α (Alpha) treatment |
Contacts plating | Rhodium |
Body material | Nylon Fiberglass |
Front panel material | Polycarbonate |
Base material | Zinc / Steel 1mm |
Max cable diameter | Ø2.8mm |
Max cable section | 5.5mm² (10AWG) |
Dimensions | 54.8 x 54.8 x 52mm |
Cutout diameter | Ø55mm |
Voltage / Current | 250VAC 16A |
Mounting holes spacing | 40 x 40mm |
Cutout for the passage of the bottom plate | 50 x 50mm |
Max cable diameter (mm) |
Mounting type |
Connectic |
Connector |
Contacts Material (Connector) |
Contacts Plating (Connector) |
Rated current (A) |
Average votes 4.7 / 5 3 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Edmond S.
Edmond S.
Patrice C.
