FURUTECH FT-SWS-D NCF (R) Dual Power Plug Schuko Type F Rhodium Plated Copper NCF
The Furutech FT-SWS-D NCF (R) is a dual wall socket with Schuko high-end connectors. Its high design quality allows it to provide an undegraded AC electrical signal that greatly contributes to the audio reproduction quality of your system.
By buying this product you get 62 loyalty points
Reference : 13690
319,00 €tax incl.
265,83 € tax excl.
Shipping date: 25-04-2025.
Dual Schuko Main Socket Rhodium Plated Copper NCF
Furutech FT-SWS-D NCF (R) Double Prise Murale Cuivre Plaqué Rhodium NCF
The contacts of these sockets are made of pure Copper with Rhodium plating, ensuring excellent signal conductivity. In addition, these contacts are processed Alpha (α). The facade of the socket is covered with a magnificent Carbon and Fiberglass cladding.
Nano Crystal² Formula (NCF)
Integrated in a selection of Furutech products, NCF is based on a special crystalline material with two active properties. First, the NCF generates negative ions that eliminate static electricity. Second, it converts thermal energy into infrared. Furutech combines this material with ceramic nanoparticles and carbon powder for their piezoelectric damping properties. Furutech thus obtains the optimal electrical and mechanical damping material.
Product typeDual main socket
Socket typeSchuko
Socket type2
Voltage/ Current250V AC 16A
Insulation materialNylon
Fiberglass
NCF
Conducteurs des connecteurs SchukoRhodium plated Non-magnetic pure Copper, Alpha (α) treatement
Front panel finishCarbon and fiberglass
Connection typeTo screw
Max cable diameterL/N : 5mm
GND : 2.8mm
Total dimensions152 x 81 x 48mm
Minimum cutout diameter121.5 x 50mm
ColorCarbon
Weight322g
Max cable diameter (mm)5.0
Max cable diameter (mm)2.8
Mounting typeTo screw
ConnecticFemale
ConnectorType F (CEE 7/3 - CEE 7/4)
Rated current (A)16.0
La cerise sur le gateau
Je pensais avoir déjà atteins l'optimum sur mon installation. He bien cette prise Furutech m'a détrompé. Plus de diaphonie, un équilibre et une sérénité dans la reproduction incroyable. La musique apparait tout simplement naturelle et évidente. Je recommande.
This review has been posted for FURUTECH FT-SWS-D NCF (R) Dual Power Plug Schuko Type F Rhodium Plated Copper NCF
The Furutech FT-SWS-D NCF (R) is a dual wall socket with Schuko high-end connectors. Its high design quality allows it to provide an undegraded AC...
