FURUTECH FT-SWS (G) Schuko wall socket Gold plated
By buying this product you get 20 loyalty points
Reference : 2931
102,90 €tax incl.
85,75 € tax excl.
Here is a beautiful Furutech wall socket with Pure Gold Plated Copper contacts. It also has "claws" to be kept in a wall slot. Its body is in Nylon / Fiberglass / Metal frame.
Specifications:
  • Recessed diameter: 55mm
  • Recessed Depth: 40mm
  • Bare weight: 320gr
  • Type: 2-poles + ground
  • Rating: 16A 250V AC
Main Features :
  • α (Alpha) Pure Copper Conductor Hand (t: 0.5mm)
  • Material: Nylon / fiberglass body and Poly carbonate cover
  • 1.0mm thick Base Bracket with a Zinc / steel brace plate
  • Cast Zn-Mg Alloy Front Plate with frosted finish.
  • Maximum cable diameter: 2.8mm or 5.5 Sq.mm/10AWG Max. (set screw)
  • Dimensions: 95.0mm (W) x 95.0mm (W) x 48.0mm (H)
  • Furutech's total attention to detail and build quality extends right down to a specially-designed Alpha Conductors.
Mounting type
  • To screw
Connectic
  • Female
Connector
  • Type F (CEE 7/3 - CEE 7/4)
