Tout part de là !
Connectique, câblage et découplage des différents maillons de votre chaine hifi ( ne jetez pas votre ancienne chaine, upgradez la !!!). En faisant cela, vous passerez d'une sono de kermesse à la vraie haute fidélité...
By buying this product you get 30 loyalty points
Wall outlet SHUCKO Furutech FT-SWS-R
Wonderful Furutech wall outlet with pure copper contacts Rhodium plated
It also has "claws" to be kept in a wall location.
Nylon Body / Fiberglass / Carbon Frame
Recessed diameter: 55mm
Recessed Depth: 40mm
Bare weight: 320gr
Type: 2-poles + ground
Rating: 16A 250V AC
Features:
• Treated with the process α (Alpha) Pure copper (t: 0.5mm)
•Material: Nylon / Fiberglass and coated with Polycarbonate
• 1.0mm thick Bracket with a Zinc / steel brace plate
• Carbon Fiber Finish Cast Zn-Mg Alloy Front Plate
• Maximum cable diameter: 2.8mm or 5.5 Sq.mm / 10AWG Max. (set screw)
• Dimensions: 95.0mm (W) x 95.0mm (W) x 48.0mm (H)
• Furutech's total attention to detail and build quality extends right down to a specially designed patent-pending pressure plate that increases the contact area of the Alpha Conductors.
Average votes 5.0 / 5 4 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Thierry L.
Sebastien F.
Samuel L.
Philippe G.
