VIBORG VE01G Power Plug Schuko Type F Pure Copper Silver / Gold Plated 250VAC 16A
The Schuko Viborg VE01G uses high quality materials to ensure perfect electrical signal transmission. The contacts are made of pure Copper and benefit from a triple plating of OFC Copper, Silver and Gold.
4.5 / 5
Reference : 15491
29,90 €tax incl.
24,92 € tax excl.
Shipping date: 22-04-2025.
Viborg VE01G
Schuko Plug Pure Copper Silver / Gold Plated 250VAC 16A
Viborg VE01G Embase Schuko Cuivre Pur Plaqué Argent / Or 250VAC 16A
The Schuko Viborg VE01G uses high quality materials to ensure perfect electrical signal transmission. The contacts are made of pure Copper and benefit from a triple plating of OFC Copper, Silver and Gold. This maximizes the conductivity of the connector, while ensuring excellent resistance to oxidation for maximum durability. The connector body is made of Nylon with Fiberglass. The assembly is extremely simple thanks to a screw-on system, without the need for soldering. The base accepts cables up to 5mm diameter.
Product typeSchuko plug
Connector typeFemale schuko
2 Poles + Ground
Voltage / Current250VAC / 16A
Contacts materialPure Copper
Contacts platingOFC Copper
Silver
Gold
InsulationNylon with fiberglass
Max. cable diameterØ5mm
ConnectionTo screw (Hex screws)
Mounting holes spacing38mm
Total dimensions51 x 51 x 38mm
Max cable diameter (mm)5.0
Mounting typeTo screw
ConnecticFemale
ConnectorSchuko
Rated current (A)16.0
4 reviews
Very high quality construction
The Viborg Schuko sockets have tank like build quality, making Furutech seem light weight.
This review has been posted for VIBORG VE01G Power Plug Schuko Type F Pure Copper Silver / Gold Plated 250VAC 16A
very interesting product
mounting this plug instead of a conventional outlet brings a clear, big, 3D sound with much details, the only drawback is a slight loss of focus.
excellente prise en audio
qualité audio indéniable : équilibre tonal et définition sans artifice. mais un peu fragile : serrage de l'embase dur le support avec précaution au risque de fendre celle-ci, les visses des plots sont à six pans creux : insérer l'outil de serrage avec attention (droit et profondément, sans faillir lors de la connexion) au risque de détruire la visse, toutefois en respectant cette attention le serrage sera puissant et sur.
Terrific
I reluctantly swapped out the silver/rhodium version of these sockets and really glad I did.
I had struggled with glare from my system for quite some time, but these seem to have taken that glare away as well as making the speakers disappear. I hear music from "space" now rather than around each speaker.
Great little investment.
The Schuko Viborg VE01G uses high quality materials to ensure perfect electrical signal transmission. The contacts are made of pure Copper and...
