The Viborg Schuko sockets have tank like build quality, making Furutech seem light weight.
Schuko Plug Pure Copper Silver / Gold Plated 250VAC 16A
The Schuko Viborg VE01G uses high quality materials to ensure perfect electrical signal transmission. The contacts are made of pure Copper and benefit from a triple plating of OFC Copper, Silver and Gold. This maximizes the conductivity of the connector, while ensuring excellent resistance to oxidation for maximum durability. The connector body is made of Nylon with Fiberglass. The assembly is extremely simple thanks to a screw-on system, without the need for soldering. The base accepts cables up to 5mm diameter.
Product type | Schuko plug |
Connector type | Female schuko 2 Poles + Ground |
Voltage / Current | 250VAC / 16A |
Contacts material | Pure Copper |
Contacts plating | OFC Copper Silver Gold |
Insulation | Nylon with fiberglass |
Max. cable diameter | Ø5mm |
Connection | To screw (Hex screws) |
Mounting holes spacing | 38mm |
Total dimensions | 51 x 51 x 38mm |
Max cable diameter (mm) | 5.0 |
Mounting type | To screw |
Connectic | Female |
Connector | Schuko |
Contacts Material (Connector) | Copper |
Contacts Plating (Connector) | Silver |
Contacts Plating (Connector) | Gold |
Rated current (A) | 16.0 |
Average votes 4.5 / 5 4 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Matt H.
Klaus M.
Michel P.
Michael B.
