LED Bargraph Voltage Supervisor Dual Column 2x5V DC
Reference : 10748
32,90 €tax incl.
27,42 € tax excl.
Shipping date: 24-04-2025.
LED Bargraph Voltage SupervisorDual Column 2x5V DC
Bargraphe LED Superviseur de Tension Double Colonne
LED bar graph indicating voltage on 3 color levels, from green (normal use zone) to orange (sensitive zone) and red (danger zone).
The measured signal is indicated in the form of a light.
Please note that this product is not a Vumeter. It is powered by a DC signal.
Electrical Specifications :
  • Can be powered on 5V DC.
  • Typical consumption 600mW.
  • Input resistance impedance for voltmeter: 500KOhm.
  • Input voltage mode.
General technical characteristics:
  • Measuring accuracy: 1% voltage per segment.
  • Plage de tension : 5V +/-10%
  • Number of segments: 2x30 segments.
  • Bargraph length 66mm.
  • Display Density: 5 segments per centimeter.
  • Bar width: 4.5mm.
  • Ratio, adjustable sensitivity 10 ~ 20%.
Dimensions and weight:
  • Dimensions: 85x22.5x16.5mm.
  • Weight: 24g.
Bargraphe LED Vumètre Double Colonne pour Affichage Tension
