LED Barmeter Dual Column for Input Voltage Display
This two-column LED barmeter indicates the input voltage of the left channel in green and the right channel in red. The measured signal is therefore indicated as a light signal on 30-segment columns.
Reference : 10980
29,90 €tax incl.
24,92 € tax excl.
LED Barmeter
Bargraphe LED Double Colonne pour Affichage Entrée Tension
This two-column LED barmeter indicates the input voltage of the left channel in green and the right channel in red. The measured signal is therefore indicated as a light signal on 30-segment columns. The bar graph provides a measured accuracy of ±0.5% F.S. per segment. The module can be powered by 12V DC.
Product typeLED Barmeter
Input modeVoltage
Measure accuracy±0.5% F.S. ±1 segment
Number of segments2x30
Display density5 segments per centimeter
RatioAdjustable sensitivity of 10-20%
Consumption600mW
Input resistance via Voltmeter> 500KΩ
Voltage supply12V DC
Dimensions / barmeter column66 x 4.5mm
Total dimensions85 x 22.5 x 16.5mm
Weight24g
This two-column LED barmeter indicates the input voltage of the left channel in green and the right channel in red. The measured signal is...
