This module is a matrix LED display with input and output, consisting of 8x32 LEDs for a total of 256 LEDs. It is the result of the assembly of 4 8x8 LED modules. The LED panel, connected to a microprocessor, can be programmed to give your system a display that will meet your needs: display of volume, source, bitrate ... In addition, it is possible to mount several modules in cascade . In such a case, each module can be controlled by a common microprocessor, enabling you not to have to code for each display.
The module also incorporates other useful features: low power off, analogue and digital brightness control, LED test mode ...
The module also exists in an 8x8 LED version (64 LEDs)
