TS-VU003 Vumeter Controller LED / Lamp
This TS-VU003 VU meter control module lets you integrate magnificent VU meters (sold separately) into your DIY audio creations, whether backlit by LED or bulb. The practical module includes variable resistors for adjusting the input level of each channel and a current regulator for adjusting the luminous intensity of your VU meters' backlighting.
Reference : 18793
14,90 €tax incl.
12,42 € tax excl.
Shipping date: 25-04-2025.
Photo of TS-VU003 LED controller
This TS-VU003 VU meter control module lets you integrate magnificent VU meters (sold separately) into your DIY audio creations, whether backlit by LED or bulb. The practical module includes variable resistors for adjusting the input level of each channel and a current regulator for adjusting the luminous intensity of your VU meters' backlighting. Moreover, this VUmeter controller can be powered from either 12V DC or 12-18V AC.
To connect your LED or lamps Vumeters, check the setting of the current regulator (7 - see diagram) on the PCB so that your LEDs do not burn out or your lamp does not light up.
Overview of the TS-VU003 Vumeter Controller
Overview of the TS-VU003 Vumeter Controller Module
112V DC power supply
212-18V AC power supply
3Signal input (L/G/R)
4DIP switch for source signal
5VU-1 amplitude adjustment
6VU-2 amplitude adjustment
7LED/LAMP output VU-1
8VU-1 output
9LED/LAMP output VU-2
10VU-2 output
Using the input source DIP switch
If you decide that the input source of the analogue signal is to come from a telephone, preamplifier or computer, then switches 1 & 3 should be in the ON position.
If, on the other hand, you decide to use a signal that has already been amplified, switches 2 and 4 should be set to the ON position. This allows the signal to be compressed almost 11 times.
DIP switch 1-3
Line level signal
Source: Telephone, computer, preamplifier, etc.
DIP switch 2-4
Amplified signal
Source : Amplifier
TS-VU003 dimensions
Product typeVumeter controller
Power supply voltage12V DC or 12-18V AC
Backlight currentTo be set with the variable current regulator
Dimensions74 x 50mm
Weight40g
Package1x Vumeter Controller TS-VU003
7x XH 2.54mm to wire cable
This TS-VU003 VU meter control module lets you integrate magnificent VU meters (sold separately) into your DIY...
