5V / 10V
This meter control module allows you to integrate beautiful LED or bulb backlit meters (sold separately) into your DIY audio creations. Conveniently, the module includes variable resistors to adjust the input level of each channel as well as the backlight intensity of your meters.
1 | Audio input |
2 | Right channel input level adjustment |
3 | Left channel input level adjustment |
4 | 6-12VDC power supply |
5 | 6-12VAC power supply |
6 | USB power supply |
7 | Audio output |
8 | Operating mode selection |
9 | LED light intensity adjustment |
10 | Bulb connectors |
11 | Bulb light intensity adjustment |
Product type | Vumeter controller |
Supplt voltage | 6-12VDC 6-12VAC 5VDC via USB |
Backlight voltage | 5V 10V |
Dimensions | 70 x 70mm |
Total dimensions | 60 x 61mm |
