White Round Vumeters with Controller Ø35mm (Pair)
These 35mm diameter white backlit meters are easy to mount and wire to an amplifier, giving your unit a beautiful vintage look. The meters are delivered with a remote controller and the necessary cables to make the connections. Moreover, this one integrates variable resistors, allowing to adjust the luminous intensity of the backlight of the vumeters as well as the amplitude of these last ones.
4.0 / 5
Reference : 16688
29,90 €tax incl.
24,92 € tax excl.
Shipping date: 16-04-2025.
Vumeters with controller
Vumètre Rond Blanc avec Contrôleur Ø35mm (La paire)
Product typeVumeters with controller
VumetersØ35mm
Internal DC resistance650Ω ±15%
Backlight voltage6-12VDC
Supply voltage12VAC
Look great, but no manual, good luck.
Nice price, I'm not sure if they work well or not because the meters didn't come with a manual and the labels are a bit misleading. The capacitors are rated at the same voltage as the AC input, shouldn't they be at least double the voltage for longevity?
The meters need the controller because they don't register like others and require higher voltages to measure sound levels (normal meters can connect directly to an output transformer for example).
Good price though, and they look good lit up, guess I will wire this up today :-p
This review has been posted for White Round Vumeters with Controller Ø35mm (Pair)
These 35mm diameter white backlit meters are easy to mount and wire to an amplifier, giving your unit a beautiful vintage look. The meters are...
