AUDIO-GD A-2 Headphone Amplifier Preamplifier Class A Discrete ACSS 2500mW
The Audio-GD A-2 is a Class A headphone amplifier and preamplifier combo that takes advantage of totally discrete analog stages to offer a high quality sound reproduction that is as neutral as possible. No AOP or coupling capacitor is used on the signal circuit
4.7 / 5
By buying this product you get 33 loyalty points
Reference : 14761
339,00 €tax incl.
282,50 € tax excl.
Audio-GD A-2
Audio-GD A-2 Amplificateur Casque Préamplificateur Class A Discret ACSS 2500mW
The Audio-GD A-2 is a Class A headphone amplifier and preamplifier combo that takes advantage of totally discrete analog stages to offer a high quality sound reproduction that is as neutral as possible. No AOP or coupling capacitor is used on the signal circuit. The output stage embeds 2 pairs of paired transistors of 20W each. On the connection side, we find stereo RCA and ACSS (Non-Feedback) on the input side as well as stereo RCA (Pre-Out) and a 6.35mm jack (headphone output) on the output side. The pure Class A headphone amplification stage allows to deliver a consequent power of 2500mW under 25Ω, to accompany all types of headphones.
The volume control on the front panel is entrusted to an ALPS 27 potentiometer. A switch allows the gain level to be adjusted to 14dB or 20dB, making the A-2 capable of adapting to high or low sensitivity headphones as well. Jumpers inside the unit allow you to adapt the sound signature of the A-2 according to your tastes.
ACSS
Audio-GD possède sa propre signature technologique appelée ACSS pour Audio-GD Current System Signal. Grâce à l'expertise et le savoir-faire de la firme, cette technologie offre un son moins coloré, plus détaillé et d'une neutralité sans équivalent.
Versatile
The DACs have variable output impedances, depending on the model. To avoid a negative effect on sound quality, the A-2 has a pair of Diamond buffers at the input. All signals from the RCA inputs pass through these to achieve a very low output impedance, regardless of whether the source has a low or high output impedance. These buffers operate in pure Class A on a very short circuit in order not to induce sound coloration.
Preamplifier
Amplification typeClass A
Headphone output power2500mW @ 25Ω
1600mW @ 40Ω
650mW @ 100Ω
325mW @ 300Ω
160mW @ 600Ω
Inputs2x Stereo RCA
1x ACSS
Outputs1x Stereo RCA
1x Jack 6.35mm headphone output
SNR> 125dB (minimum volume)
THD< 0.008%
GainL (low) : +14dB
H (high) : +20dB
Preamplifier output level8V
Input impedanceRCA : 47kΩ
ACSS : < 10Ω
Frequency response (ACSS)20Hz - 20kHz (±0.3dB)
10Hz - 125kHz (+0dB, -3dB)
Supply voltage220-240V AC 50/60Hz
Consumption20W
Weight3.5kg
Dimensions240 x 240 x 85mm
Package1x Audio-GD A-2
1x Power cable
Audio-GD A-2 Amplificateur Casque Préamplificateur Class A Discret ACSS 2500mW Audio-GD A-2 Amplificateur Casque Préamplificateur Class A Discret ACSS 2500mW Audio-GD A-2 Amplificateur Casque Préamplificateur Class A Discret ACSS 2500mW
InputACSS
OutputJack 6.35mm
ClassClass A / AB
3 reviews
Casque mais aussi préamp ligne exceptionnel ...
Son chaud, beaucoup de matière et présence, belle transparance et définition, spatialisation 3D
Très surprenant pour le prix ... !
Je revends les autres pré achetés précédemment ...
Ils ne tiennent pas la comparaison ...
Me rapelle mon regretté Musical Fidelity F2, mais l'Audio GD va plus loin en terme de transparence, comme le F2, on penserait qu'il y a des tubes ... et bien non ... !!
This review has been posted for AUDIO-GD A-2 Headphone Amplifier Preamplifier Class A Discrete ACSS 2500mW
Pas déçu !
Pour commencer j'ai acheter d'abord le Sennheiser HD 660S, ensuite j'ai tenter l'expérience avec un ampli vendu par Audiophonics en classe A le K214 V2, déçu je le renvois, l'ampli étais bon mais pas pour mon casque.. Je tente encore avec un ampli casque à lampes le Little Dot MK2 rien à dire c'était très bon mais ça manquais un peu de puissance à mon gout. (je conseil d'ailleurs de changer les lampes d'entrées c'était devenu une petite merveille sur le medium)
Et enfin je décide enfin de passer sur l'audio gd, il à repris les qualités de tout les autres appareil avec un surplus de puissance conséquent, il vaut vraiment son prix et on sent clairement le "Class A" à l'écoute, on peux le mettre en mode son "Chaud" avec les jumpers "non fournis", j'ai préférer sans je le trouve très chirurgical.
#niveau chauffe sans plus, ça chauffe quoi mais sans être alarmant pour autant.
#Pour ce qui est de la source, j'utilise un SMSL SU-8 V2 qui traite le son de mon pc en optique 24bits/192 000hz pour sortir en XLR sur l'audio GD.
Bien, mais peut mieux faire
L'absence de notice est un peu gênant, l'utilisation des straps. pour modifier l'équilibre tonal n'est pas très aisé. Sur la position zéro du sélecteur de gain et volume au maximum, une tension parasite de faible amplitude et de 0,5 Hz environ apparait sur la sortie audio. Ce phénomène entraine un déplacement insolite des membranes des boomers. Ce phénomène disparait en sélectant le gain sur 1. Heureusement la qualité sonore est au rendez-vous.
The Audio-GD A-2 is a Class A headphone amplifier and preamplifier combo that takes advantage of totally discrete analog stages to offer a high...
