AUNE T1SE 24bit / DSD Headphone Amplifier USB DAC 24bit/192kHz XMOS Silver
Reference : 10577
249,00 €tax incl.
207,50 € tax excl.
The AUNE T1Se is the latest generation of this small hybrid headphone amplifier with super neo-retro design.
Now equipped with an XMOS interface, it also acts as an analog digital converter capable of decoding the PCM up to 24bit / 192khz and the Native DSD.
Pulling out of the best of both worlds this low priced amplifier features the transistors dynamics associated with the heat of the Electro-Harmonix tube 6922EH.
The DAC part is equipped with a TEXAS DSD1793 and its USB interface XMOS supports 24bit / 192kHz and DSD.
This device is particularly good at reviving digital recordings that lack heat.
Features:/ Strong>
  • DAC: TEXAS DSD1793
  • Interface: USB XMOS
  • Tube: 6922 compatible EH (6DJ8 / ECC88 / 6922 / E88CC / ​​6N23P / 6N23P-EB)
  • Silver color
  • Housing Aluminum
  • Weight: 1.5 kg
  • Size: 155mm x 97x 40mm
  • Frequency response: 20hz-20khz
  • Noise Ratio: -105db
  • Line Output: 2Vrms
  • Headphone Output Power: 300ohm - 240MW
  • Supported Sampling Rates: 24bit / 192kHz / DSD64
  • Inputs: Analog stereo RCA, USB
  • Outputs: Analog stereo RCA, 6.35 mm jack
  • Comes with power supply, USB cable and 1 x Adapter Jack 6.35 to 3.5mm Female Stereo Jack
