ifi Audio PRO iCAN SIGNATURE Tubes Preamplifier / Headphone Amplifier
The iFi Pro iCAN SIGNATURE tube preamplifier and headphone amplifier is the quintessence of the know-how of the brand itself supported by the prestigious company AMR. Based on a hybrid circuit of transistors and tubes, the iFi Pro iCAN SIGNATURE embeds the best of these two technologies and not a caricatural compromise.
We can therefore choose the sound as desired by inserting the tube or only transistor sound into the circuit.
By buying this product you get 224 loyalty points
Reference : 17540
2 249,00 €tax incl.
1 874,17 € tax excl.
 Tube Preamplifier / Headphone Amplifier
ifi AUDIO PRO ICAN SIGNATURE
The stereo input is via a very low distortion fast JFET transistor stage accompanied by a bipolar stage assisted by a class A Mosfet stage. The tube stage is amplified by two 5670 GEs as close as possible to the ALPS "Black Beauty" potentiometer. "6-track in true balanced mode.
Thus the iFi pro iCAN SIGNATURE stereo preamplifier is fully symmetrical from input to output on a 4-layer printed circuit.
The circuit diagram fully optimized in current-coupled mode has no capacitors in its path that could degrade the original signal.
Only handpicked components are in this preamplifier: Vishay MELF capacitors, TDK COG for the audio part, Elna Silmic II and Panasonic Foil for the power supply part.
This symmetrical stereo preamplifier is a studio quality headphone amplifier capable of delivering very high power (14000mW) to "drive" any of the most demanding symmetrical audiophile models, in particular models from Sennheiser, Audeze and Hifiman.
Like any high-end headphone amplifier, the gain is fully adjustable in three positions: 0dB, 9dB, 18dB.
Audio inputs and outputs of the PRO ICAN SIGNATURE
ifi AUDIO PRO ICAN SIGNATURE ifi AUDIO PRO ICAN SIGNATURE
Gain0dB, 9dB, 18dB to select with switch
Tube2 tubes 5760 GE
Frequency response0.5Hz to 500kHz(-3dB)
Total harmonic distorsionTransistor stage : ≤0.0015% ≤0.005%, Tube+: ≤0.012% ≤0.2%
SNRBalanced : >147dB(A)
Unbalanced : > 137dB(A)
Output powerBalanced >14,000mW @ 16Ω
Unbalanced >4,800mW @ 16Ω
Voltage level for 600 ΩBalanced : >23V
Unbalanced : >11.5V
Average power consumption≤ 22W, 50W max
Inputs3x RCA stereo unbalanced gold plated
1x XLR balanced
Outputs1x XLR variable balanced
1x RCA variable unbalanced gold plated
2x Jack 6.35mm switchable to a balanced output
1x headphone output 4 pins balanced
1x Jack 3.5mm TRS unbalanced
1x Jack 3.5mm TRS balanced
Dimensions213x 193 x 63 mm
Net Weight1.93kg
Total Weight6kg
InputXLR
OutputJack 6.35mm
OutputJack 3.5mm
ColorSilver
ClassTube amp
Remote ControlYes
The iFi Pro iCAN SIGNATURE tube preamplifier and headphone amplifier is the quintessence of the know-how of the brand itself supported by the...
