By buying this product you get 32 loyalty points
Topping E30 AK4493 DAC + Topping L30 Headphone Amplifier + Topping TCR2 RCA Cables
This Topping pack consists of an E30 DAC based on an AKM AK4493 conversion chip, an L30 headphone amplifier and preamplifier combo and a pair of RCA cables to connect the two devices. This set will allow you to enjoy a high quality audio system for headphone listening at an affordable price and with a reduced form factor.
The E30 from Topping is a DAC with very advantageous compact dimensions and surprisingly good performance, considering its small size. It embeds an AKM AK4493 DAC chip, a very famous component in the high-fidelity audio world, as well as an XMOS interface offering a clear and transparent link with your digital sources equipped with a USB output. This DAC has an integrated and bypassable volume control function. It can therefore be connected directly to an amplifier or active speakers, as well as to a preamplifier. The aesthetics is not left out as the E30 has an elegant and readable display, accompanied by a touch control button of the most beautiful effect.
VIEW THE FULL DESCRIPTION OF THE TOPPING E30The Topping L30 is a headphone amplifier with a preamplifier function that is compact, affordable and above all extremely powerful! It benefits from excellent measurements, allowing it to deliver an incredibly precise, rich and dynamic sound reproduction.
VIEW THE FULL DESCRIPTION OF THE TOPPING L30" The race toward perfection and beyond continues in headphone amplifiers at incredibly low prices. The L30 is the latest offering, firmly grabbing the top of the class and holding on to it. Its functionality is excellent and price is very reasonable. "
Topping offers with the TCR2 a very good male to male RCA cable. It benefits from a very nice design with a silver plated OFC copper conductor offering an excellent signal conductivity, as well as gold plated copper connectors, the latter being oxidation resistant for a more durable cable. A blue and red sheath finishes this cable, giving it both a very nice aesthetic but also a greater longevity.
VIEW THE FULL DESCRIPTION OF THE TOPPING TCR2Topping E30 Specifications | |
Product type | DAC |
DAC Chip | AKM AK4493 |
Supported sampling rates | USB : PCM up to 32bit 768kHz, Native DSD up to DSD512 Optical, Coaxial : PCM up to 24bit 192kHz, DSD DoP up to DSD256 |
THD+N | 0.0003% |
Crosstalk | < -130dB |
SNR | 121dB |
Dynamic range | 119dB |
Dimensions | 100 x 125 x 32mm |
Color | Black |
Topping L30 Specifications | |
Product type | Headphone amplifier |
Inputs | 1x Stereo RCA |
Outputs | 1x Jack 6.35mm headphone output 1x Pre-Out stereo RCA |
Output power | 2x 3500mW @ 16Ω, THD+N < 0.1% 2x 2300mW @ 32Ω, THD+N < 0.1% 2x 280mW @ 300Ω, THD+N < 0.1% |
Gain | -9.9dB / 0dB / +9.5dB |
THD+N @ 1kHz, A-Weighting | Headphone amplifier : < 0.00007% @ Sortie = 500mW Preamplifier : < 0.00009% |
Dynamic range @ 1kHz, A-Weighting | Headphone amplifier : 141dB Preamplifier : 141dB |
SNR @ Max out level, 1kHz, A-Weighting | Headphone amplifier : 141dB Preamplifier : 141dB |
Frequency response | Headphone amplifier : 20Hz - 40kHz (±0.05dB) Preamplifier : 20Hz - 40kHz (±0.05dB) |
Measured noise level | Headphone amplifier : < 0.7µVrms @ G=L, < 0.7µVrms @ G=M, < 0.9µVrms @ G=H Preamplifier : < 0.7µVrms @ G=L, < 0.7µVrms @ G=M, < 0.9µVrms @ G=H |
Output level | Headphone amplifier : 26Vpp @ G=L, 26Vpp @ G=M, 26Vpp @ G=H Preamplifier: 26Vpp @ G=L, 26Vpp @ G=M, 26Vpp @ G=H |
Crosstalk @ 1kHz | Headphone amplifier : -91dB Preamplifier : -91dB |
Input sensitivity | Headphone amplifier : 25Vrms @ G=L, 9Vrms @ G=M, 3Vrms @ G=H Preamplifier : 25Vrms @ G=L, 9Vrms @ G=M, 3Vrms @ G=H |
Output impedance | Headphone amplifier : < 0.1Ω Preamplifier : 20Ω |
Topping TCR2 Specifications | |
Product type | RCA Cables |
Length | 25cm |
Conductor material | OFC Copper |
Conductor plating | Silver |
Total section | 2x 0.533mm² |
Conductor resistance | 26.9Ω/km |
External diameter | Ø8mm |
Connectors material | Copper |
Connectors plating | Gold |
Color | Black |
Input | SPDIF |
Input | USB |
Input | Optical |
Output | RCA |
Output | Jack 6.35mm |
Color | Black |
Class | N/A |
Remote Control | Yes |
