SINGXER SA-1 Headphone Amplifier Preamplifier Class A Balanced
The Singxer SA-1 is a high-performance, full-featured headphone amplifier and preamplifier based on Class A architecture and discrete, fully balanced circuitry. Completely analog, there is no EMI interference from digital control to disrupt the audio signal.
Reference : 14991
499,00 €tax incl.
415,83 € tax excl.
This product has been replaced by the new version, the SINGXER SA-1 V2 Headphone amplifier.
Singxer SA-1
Singxer SA-1 Amplificateur Casque Préamplificateur Symétrique
The Singxer SA-1 is a high-performance, full-featured headphone amplifier and preamplifier based on Class A architecture and discrete, fully balanced circuitry. Completely analog, there is no EMI interference from digital control to disrupt the audio signal. ROHM input transistors provide very low noise and excellent performance. The output stage uses multi-stage current amplification, similar to that found in a high-power amplifier. Each channel has 2 pairs of 4A ON Semiconductor transistors to ensure low internal resistance and high output power. These circuits also incorporate a complete protection system against overcurrents, overloads, short circuits as well as thermal protection, DC protection and switch-on delay.
This SA-1 also has a complete set of connectors. The input is asymmetrical RCA and symmetrical XLR. For the headphone outputs, the amplifier offers 4.4mm jack and 4-pole XLR balanced, and 6.35mm jack unbalanced. On the preamplifier output side, the SA-1 provides an unbalanced RCA output and a balanced XLR output.
In order to fit any type of headphones or earphones, whether they are high-sensitivity or high-impedance models, the SA-1 offers a choice of gain (low or high).
Test du Singxer SA-1 par Audio Science Review (Amir)
" Clearly the Singxer SA-1 is designed using instrumentation to make sure it delivers extremely low levels of noise and distortion. While our testing is stressful enough to show a slight weakness in driving low impedance headphones, the unit is nevertheless worthy of top of the class designation in my book. "
Preamplifier
Amplification typeClass A
Inputs1x Balanced XLR
1x Single-ended RCA
Outputs1x Balanced XLR
1x Single-ended RCA
1x Balanced Jack 4.4mm headphone output
1x Balanced XLR 4 poles headphone output
1x Single-ended Jack 6.35mm headphone output
THD+N-120dB @ 1kHz, A-Weighting, 20Hz - 22kHz
-96dB @ Low gain, 1kHz, A-Weighting, 20Hz-22kHz
Noise level0.66µV @ Max output, SNR / DNR 147dB
300nV RMS @ Low gain, A-Weighting, 20Hz-22kHz
Output power6480mW @ 32Ω
2000mW @ 120Ω
380mW @ 600Ω
Power supply100-240V AC, 50/60Hz
Dimensions234 x 170 x 46mmmm
Housing materialAluminum
Weight1.8kg
Package1x Singxer SA-1
1x Power cable
InputXLR
OutputJack 4.4mm
OutputJack 6.35mm
ClassClass A / AB
3 reviews
Pour les amoureux de la classe A !
Depuis la découverte il y a 20 ans d'un ampli Sugden, j'adore la classe A. Je n'ai jamais pu essayer leur ampli casque... rare et cher.
Je cherchais donc un ampli casque (pour HD800S & LCD2-C) dans un budget "raisonnable" et à transistors.
Avec ce SA-1, on retrouve bien la douceur de la classe A, une sorte de chaleur qui répond bien à mes attentes, cet ampli ne joue pas dans le bling bling, physique discret, boutons à l'ancienne (switchs du gain placés en dessous ? Mis sur élevé et on y touche plus, curieux tout de même), mais la qualité du son tout comme son assemblage est parfait (les photos de l'intérieur respirent la qualité).
Il est suffisamment puissant alimenter la grande majorité des casques.
Au début, on s'étonne à monter le volume (très progressif au début) pour obtenir un volume correct, puis sur la fin, le volume monte plus rapidement, jusqu'à des niveaux pas raisonnables.
Une belle découverte, si vous aimez la classe A, les ampli capable de driver vos casques avec une main de fer dans un gant de velours, il faut essayer cet ampli.
This review has been posted for SINGXER SA-1 Headphone Amplifier Preamplifier Class A Balanced
Excellent discreet balanced amplifier in the price/performance ratio.
The SINGXER SA-1 is an excellent headphone amplifier and preamplifier for active speakers.
Its quality surpasses, for example, the cheaper Schiit Jotunheim 2 or MONOLITH THX AAA-887. If you want a better amp, go for more expensive ones like Burson Audio Soloist 3X Performance or HeadAmp GS-X Mini.
If you are going to use the SINGXER SA-1 in combination with a DAC, I recommend choosing one with enough power to drive the SINGXER SA-1 amplifier. I use it with the powerful RME ADI 2 DAC FS via balanced XLR cables and I am extremely satisfied. Other recommended DACs are Denafrips Ares II, GUSTARD X26 PRO.
I use HiFiMAN Ananda Stealth and HiFiMAN Sundara headphones. Other headphones I would highly recommend for this amp are the more expensive HiFiMAN Arya Stealth, Audeze LCD2 and LCD-X or Focal Clear Mg.
The sound of SINGXER SA-1 is very very clean (almost dead silent), detailed, smooth and warm with a lot of space, separation of instruments and soundstage.
I highly recommend this amp for purchase at a great price!!!
 (3)
Excellent amp!
Extra clean amp with a touch of sonic quality, very pleasant and comfortable to the ears!
The Singxer SA-1 is a high-performance, full-featured headphone amplifier and preamplifier based on Class A architecture and discrete, fully...
