SMSL M10 Headphone Amplifier & DAC Balanced TPA6120A2 AK4497 32bit 768kHz DSD512
The SMSL M10 is intended to be a versatile HiFi device, integrating both a DAC and a headphone amplifier. It integrates excellent components into a beautiful housing to ensure high performance. Versatile and efficient, it is a device that will adapt to most audio systems for high quality playback and listening.
By buying this product you get 51 loyalty points
Reference : 13176
519,00 €tax incl.
432,50 € tax excl.
SMSL M10
Balanced headphone DAC & Amplifier TPA6120A2 AK4497 32bit 768kHz DSD512
SMSL M10 Amplificateur & DAC Casque SymétriqueTPA6120A2 AK4497 32bit 768kHz DSD512
AKM AK4497 DAC
The M10 conversion stage is based on an excellent AK4497 chip from Asahi Kasei. This supports streams up to 32bit 768kHz but also DSD up to DSD512. You'll enjoy high quality files and rich, detailed sound reproduction. In addition, this chip incorporates the proprietary Velvet Sound™ technology that offers a very low level of distortion but also a wide dynamic range. It also incorporates "OSR Doubler" switched capacitor circuits to minimize noise while reducing power consumption.
SMSL M10 DAC AKM AK4497
SMSL M10 amplificateur TPA6120A2
TPA6120A2 Amplifiers
On the headphone amplification side, there are two TPA6120A2 chips in a symmetrical mounting with volume control allowing perfect synchronization of the left and right channels. These chips are capable of delivering a wide frequency response while maintaining extremely low noise and a dynamic range up to 128dB. These chips also assert themselves by a high scanning speed in order to limit distortion and the appearance of sound anomalies, its ability to deliver the current adapted according to situations, for a beautiful linearity and dynamics without increasing the noise or degradation of the SNR and finally its frequency response independent of the gain allowing to use the wide frequency response allowed by these amplifiers whatever the gain.
Complete connectic
The M10 offers full connectivity to fit the vast majority of audio systems. The SPDIF Coaxial and Optical as well as the USB Type B are used as inputs. On the output side, the device has on its front panel two headphone outputs in 6.35mm Jack and XLR 4 pole balanced format. On its rear panel the DAC / Amplifier offers unbalanced RCA stereo output and balanced XLR output.
SMSL M10 connectique
SMSL M10 composants
Only high quality components
While the amplification and conversion chips show great performance, the rest of the components are not left out with excellent design quality. This includes a Norwegian Noratel brand transformer with a clean power supply and an anti-vibration chassis. The M10 also features 5 AOP OPA1602, a very low phase noise clock coupled to a CPLD for a drastically lowered jitter and finally, for USB, an excellent XMOS interface supporting sampling rates up to 32bit 768kHz and DSD512.
Beautiful design
The housing, made entirely of anodized aluminium, is CNC-machined, i.e. an ultra-precise computer-controlled machine. This makes it possible to obtain a smooth rendering, each angle being cut with the greatest precision. The M10 also features a slightly sloping front panel, giving it a distinctive appearance but also offering greater ease of use. The screen allows him to display the various information of the device such as the active source, the sampling rate of the file read or the volume. A remote control is also provided for convenient remote control.
SMSL M10 Design
Schema
Dimensions
Techincal characteristics
DACAKM AK4497
Amplifier chipTI TPA6120A2
OPA5x OPA1602
USB InterfaceXMOS
Inputs1x USB-B
1x Optical
1x Coaxial
Outputs1x Stereo RCA
XLR 6.35mm (Balanced)
THD+NLine output : 0.0004%
Amp outout : 0.001%
Dynamic range123dB
SNR116dB
USB transmission modeAsynchronous
USB compatibilityWindows 7 / 8 / 8.1 / 10, Mac OSX 10.6 ou more recent, Linux
Sampling rateUSB : up to 32bit 768kHz / DSD 2.8224 - 22.5792MHz
Optical, Coaxial : 24bit 192kHz
RCA output level2Vrms
XLR output level4Vrms
Headphone output powerSingle-Ended : 135mW @ 32 Ohm, 90mW @ 64 Ohm, 40mW @ 150 Ohm, 22mW @ 300 Ohm
Balanced : 340mW @ 32 Ohm, 266mW @ 64 Ohm, 154mW @ 150 Ohm, 87mW @ 300 Ohm
Consumption9W
Standby consumption0.8W
Dimensions250 x 50 x 205mm
OutputJack 6.35mm
Download
Driver SMSL 2018 V4.47
Windows Driver (newest version)
Download (2.79M)
M10 DSD Update
DSD firmware (use only if you have trouble playing DSD)
Download (2.43M)
The SMSL M10 is intended to be a versatile HiFi device, integrating both a DAC and a headphone amplifier. It integrates excellent components into a...
