J’ai un setup hifi plutôt hdg mais pour ce qui est d’écouter au casque je suis moins exigeant. Une bonne surprise cet ampli qui n’a pas vraiment de signature sonore. Pour avoir eu un rme adi-2fs il est au dessus.
NFCA Headphone Amplifier Silver
The Topping A30 Pro is a high quality headphone amplifier that will delight lovers of headphone listening. With two headphone outputs at different impedances and a three-level adjustable gain, it will work with all types of headphones. Its symmetrical amplification circuit allows it to offer excellent performance, ensuring great precision and richness of sound.
On the connection side, the A30 Pro offers balanced XLR or unbalanced RCA inputs. For its headphone outputs, the amplifier offers unbalanced 6.35mm jack, as well as 4-pin XLR and unbalanced 4.4mm jack. The A30 Pro also offers two pass-through outputs with unbalanced RCA or two mono 6.35mm jacks for the balanced output. These are not preamplifier outputs.
The A30 Pro takes advantage of the new optimized NFCA circuit to achieve incredible unbalanced performance. The 10 OPA1656 AOPs connected in parallel and the UHGF (Ultra High Gain Feedback) technology ensure excellent AC and DC characteristics. The high current of the Topping A30 Pro allows it to be used with a wide range of headphone models without difficulty. Measured characteristics such as an ultra low noise of only 0.3µV or a dynamic range of 145dB allow the Topping A30 Pro to offer a rich, precise and lively sound reproduction.
The Topping A30 Pro offers a complete panel of connectors. We find unbalanced RCA and balanced XLR on the input. On the output side, we find unbalanced RCA but also a balanced output on two pass-through mono 6.35mm jacks, as well as three headphone outputs in balanced 4.4mm jack, balanced XLR 4 pins and unbalanced 6.35mm jack.
Furthermore, in the case of an RCA use with several devices, a GND/LIFT switch allows to cancel the noise that can be generated by ground loops. The LIFT position allows you to use the ground of the connected equipment instead of the A30 Pro.
Finally, we note that in the case of the use of a headphone with an impedance higher than 250Ω, the A30 Pro works in Class A.
Versatile, the A30 Pro adapts to all types of headphones, notably thanks to an adjustable gain in 3 levels. The amplifier is equally at home with highly sensitive in-ear monitors and high-impedance headphones.
" Just when we thought we had reached a plateau with performance of headphone amps, Topping pushes a bit more in the form of lower noise and much more power in unbalanced mode. It goes without saying that it is my absolute pleasure to recommend Topping A30Pro headphone amplifier. "
Product type | Headphone amplifier |
Inputs | 1x Single-ended stereo RCA 1x Balanced stereo XLR |
Outputs | 1x Single-ended Jack 6.35mm headphone output 1x Single-ended Jack 4.4mm headphone output 1x Single-ended XLR 4 poles headphone output 1x Single-ended stereo RCA (pass through) 2x Balanced mono Jack 6.35mm (pass through) |
THD | 0.00009% @ 1kHz |
SINAD | 121dB |
SNR | 128dB @ Medium Gain, 4V In/Out 95dB @ Medium Gain, 50mV Out, 600Ω |
Frequency response | 10Hz - 30kHz |
Measurements | ||
Single-ended input | Balanced input | |
THD+N @ 1kHz A-Weighting | < 0.00007% @ 3.5W, 32Ω < 0.00006% @ 90mW, 300Ω | < 0.00007% @ 3.2W, 32Ω < 0.00006% @ 86mW, 300Ω |
THD @ 20Hz-20kHz 90kBW | < 0.00008% @ 760mW, 32Ω < 0.00007% @ 81mW, 300Ω | < 0.00007% @ 760mW, 32Ω < 0.00007% @ 81mW, 300Ω |
SNR @ Max Out, 1kHz, A-Weighting | 145dB | 140dB |
SNR @ 50mV Out, 1kHz | 104dB | 104dB |
Dynamic range @ 1kHz, A-Weighting | 145dB | 140dB |
Frequency response | 20Hz-40kHz (±0.05dB) | 20Hz-40kHz (±0.1dB) |
Output level | 34Vpp @ G=L 34Vpp @ G=M 45Vpp @ G=H | 6.6Vpp @ G=L 34Vpp @ G=M 45Vpp @ G=H |
Noise level @ A-Weighting | < 0.3µVrms @ G=L < 0.3µVrms @ G=M < 0.9µVrms @ G=H | < 0.3µVrms @ G=L < 0.3µVrms @ G=M < 1.1µVrms @ G=H |
Crosstalk @ 1kHz | -106dB | -101dB |
IMD CCIF @ 18kHz+19kHz | -116dB | -116dB |
IMD SMPTE @ 60Hz+7kHz | -110dB @ SMPTE4:1 -115dB @ SMPTE1:1 | -110dB @ SMPTE4:1 -116dB @ SMPTE1:1 |
Input sensitivity | 60Vrms @ G=L 12.6Vrms @ G=M 2.7Vrms @ G=H | 12.7Vrms @ G=L 12.7Vrms @ G=M 2.7Vrms @ G=H |
Gain | -14dB @ G=L 0dB @ G=M 14dB @ G=H | -14dB @ G=L 0dB @ G=M 14dB @ G=H |
Output impedance | < 0.1Ω | < 0.1Ω |
Output power | 2x 6000mW @ 16Ω, THD+N < 0.1% 2x 5500mW @ 32Ω THD+N < 0.1% 2x 840mW @ 300Ω, THD+N < 0.1% |
Dimensions | 174x138x45mm |
Net weight | 870g |
Color | Silver |
Package | 1x Topping A30 Pro 1x Power cable 1x Jack 3.5mm female to Jack 6.35mm male adapter |
Input | RCA |
Input | XLR |
Output | RCA |
Output | Jack 6.35mm |
Output | XLR |
Output | Jack 4.4mm |
Color | Silver |
Class | N/A |
Remote Control | No |
Average votes 4.5 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Cédric R.
