TOPPING A50 Balanced Headphone Amplifier Black
The Topping A50 is an efficient and affordable sedentary headphone amplifier. Its careful design makes it an ideal ally for any audiophile wishing to enjoy a rich and clear headphone listening experience. The amplifier is Hi-Res certified, a label that guarantees a very good sound quality.
Reference : 14256
169,00 €tax incl.
140,83 € tax excl.
This model is replaced by the new version : Topping A50S
Topping A50
Balanced Heaphone Amplifier Black
Topping A50 Amplificateur Casque Symétrique Noir
Balanced / Single-ended connectivity
For its connectivity, the A50 is both simple and very efficient. It integrates a single stereo RCA input but has 3 headphone outputs, one of which is balanced on a 2.5mm jack connector. A stereo RCA line output is also available on the back of the unit.
Aluminium case
The components of the A50 Topping are hidden under a beautiful and robust CNC machined Aluminium housing. It is also designed to effectively dissipate the heat released by the power supply and PDOs.
Digital volume
The A50 scans the position of the volume knob and transmits the data to the JRC1195 controller for a precise adjustment of the volume level. This chip also provides a perfect volume balance between the left and right channels.
AOP
The amplifier includes a pair of LME49720 PDOs mounted on a DIP8 bracket. It is therefore possible to easily replace these PDOs to adapt the sound reproduction to your listening experience.
Regulated power supply
The power supply circuit of the A50 is stabilized by low noise TI TPS7A33/47 linear regulators. These high-performance chips provide clean and stable power to all A50 circuits.
A50 Headphone amplifier + P50 Power supply + D50s DAC Association
The Topping A50 completes the range also composed of the P50 and D50s. The combination of these products is ideal and allows you to benefit from a complete and efficient system. The D50s DAC allows efficient digital-to-analog conversion, supports high-resolution files and allows Bluetooth transmission. The ultra-low noise regulated linear power supply P50 will provide the A50 and D50s with an extremely clean power supply, allowing them to reach their full potential.
Topping A50 Amplificateur Casque Symétrique NoirTopping A50 Amplificateur Casque Symétrique Noir
Input1x Stereo RCA
Outputs1x Stereo RCA
1x Single-ended Jack 3.5mm headphone output
1x Single-ended Jack 6.35mm headphone output
1x Balanced Jack 2.5mm headphone output
THD+N : Single-ended output (@ A-Weighting)< 0.0006% @ 1kHz, 100mW 32Ω
< 0.0015% @ 20Hz - 20kHz, 100mW 32Ω
< 0.0006% @ 1kHz, 12mW 300Ω
< 0.0006% @ 20Hz - 20kHz, 12mW 300Ω
THD+N : Balanced output (@ A-Weighting)< 0.0016 @ 1kHz, 100mW 32Ω
< 0.0022% @ 20Hz - 20kHz, 100mW 32Ω
< 0.0004% @ 1kHz, 50mW 300Ω
< 0.0004% @ 20Hz - 20kHz, 50mW 300Ω
SNR (@ A-Weighting)123dB @ 1kHz
Dynamic range (@ A-Weighting)123dB @ 1kHz
Frequency responseGain 0dB : 20Hz - 20kHz ±0.6dB
Gain 9dB : 20Hz - 40kHz ±0.6dB
Output levelSingle-ended, Gain 0dB : 10.6Vpp
Single-ended, Gain 9dB : 20Vpp
Balanced, Gain 0dB : 21.4Vpp
Balanced, Gain 9dB : 40Vpp
Noise (@ A-Weighting)Single-ended, Gain 0dB : < 3µVrms
Single-ended, Gain 9dB : < 5µVrms
Balanced, Gain 0dB : < 5µVrms
Balanced, Gain 9dB : < 10µVrms
Output impedanceSingle-ended : < 4.7Ω
Balanced : < 9.4Ω
Output powerSingle-ended, Gain 0dB : 2x 1110mW @ 32Ω, THD+N < 1%
Single-ended, Gain 9dB : 2x 160mW @ 300Ω, THD+N < 1%
Balanced, Gain 0dB : 2x 2200mW @ 64Ω, THD+N < 1%
Balanced, Gain 9dB : 2x 640mW @ 300Ω, THD+N < 1%
Compatible headphone impedanceSingle-ended : 16-300Ω
Balanced : 16-600Ω
Case materialAluminium
Dimensions11 x 12.3 x 2.6cm
Package1x Topping A50
1x Power supply
OutputJack 6.35mm
OutputJack 3.5mm
OutputJack 2.5mm
The Topping A50 is an efficient and affordable sedentary headphone amplifier. Its careful design makes it an ideal ally for any audiophile wishing...
