XDUOO XA-10 Headphone Amplifier Balanced DAC 2x AK4493 Bluetooth 5.0 32bit 768kHz DSD512
The xDuoo XA-10 is a balanced headphone and DAC desktop combo amplifier. With a beautiful design, it delivers excellent audio performance for rich, accurate and immersive listening.
4.7 / 5
By buying this product you get 40 loyalty points
Reference : 15105
409,00 €tax incl.
340,83 € tax excl.
Shipping date: 25-02-2025.
xDuoo XA-10
xDuoo XA-10 Amplificateur Casque DAC Symétrique 2x AK4493 Bluetooth 5.0 32bit 768kHz DSD512
Balanced circuit
The XA-10 features a fully balanced audio circuit based on two AKM AK4493 DACs and two amplifier chips. This architecture ensures excellent sound reproduction, including reduced interference, crosstalk and background noise. It also enables it to deliver considerable power to accompany all types of headphones.
In addition, the XA-10 supports high sample rates, especially via its USB inputs: up to 32bit 384kHz PCM, DSD512 as well as MQA.
Connectics
The XA-10 is equipped with a rich connectivity, and offers Coaxial, Toslink Optical, USB-B and RCA stereo inputs. For its outputs, there is a 6.35mm jack as well as a 4.4mm jack and a balanced 4-pin XLR.
Bluetooth
The XA-10 also includes a Bluetooth receiver chip. It is thus possible to broadcast your music remotely, directly from your smartphone. It supports SBC, AAC, aptX, aptX LL, aptX HD and LDAC transmission codecs.
Class A Buffer
The XA-10's Class A buffer uses a series of transistors to maintain the circuit in the best possible operating conditions.
Product typeDAC
InputsBluetooth 5.0
1x Stereo RCA
1x Coaxial
1x Optical Toslink
1x USB-B
Outputs1x Stereo RCA
1x Single-ended headphone output Jack 6.35mm
1x Balanced headphone output Jack 4.4mm
1x Balanced headphone output XLR 4 poles
DAC Chips2x AKM AK4493
USB InterfaceXMOS XU208
Bluetooth version5.0
THD0.0008%
SNRBalanced: 120dB
Single-ended: 115dB
CrosstalkBalanced: 108dB
Single-ended: 73dB
Output powerBalanced: 4000mW @ 32Ω, 1kHz
Single-ended: 3000mW @ 32Ω, 1kHz
Recommanded headphone impedance16-600Ω
Gain+18dB
Supported sampling ratesUSB : PCM up to 32bit 768kHz, DSD up to DSD512, DXD up to 32bit 384kHz, MQA up to 32bit 384kHz
Optical / Coaxial : PCM up to 24bit 192kHz, DSD up to DSD64
Supported Bluetooth codecsSBC, AAC, aptX, aptX HD, aptX LL, LDAC
ScreenOLED 0.96"
Dimensions22 x 7 x 10cm
Weight900g
OutputJack 6.35mm
OutputJack 4.4mm
DAC / ADC ChipAK4493EQ
Max sampling rate768kHz
Max sampling rateDSD512
ColorGray
ClassN/A
3 reviews
Great product
Great sounding and fully featured product, at a very reasonable price.
Congrats also to Audiophonics for the easy ordering process and quick delivery; I will definitely consider purchasing again from them in the future.
This review has been posted for XDUOO XA-10 Headphone Amplifier Balanced DAC 2x AK4493 Bluetooth 5.0 32bit 768kHz DSD512
Parfait
Bel appareil bien fini, nombreuses possibilités de branchement et caractéristiques de premier ordre.
La prise en main est très facile.
A l'écoute le son procuré est simplement superbe sur toute l'étendue du spectre audio (respectueux du message originel)
De plus la possibilité de branchement symétrique est un plus.
Je suis plus que satisfait de cet achat, que je peux recommander.
Sounds good but...
Sounds Good but need some improvements, first buy better and longer usb cable to put the pc or phone far of dac for avoid interferences, the dac need a bit of isolation, separate the electric and audio cable if you use the rca output.
Rca output sound incredible for stereo sistems.
Filters except 4 and 2 don't work, are inaudible.
rca in dont work
The xDuoo XA-10 is a balanced headphone and DAC desktop combo amplifier. With a beautiful design, it delivers excellent audio performance for rich,...
