Yulong A18 Amplifier Class A Silver Balanced Headphone
High-end headphone amplifier of the brand, integrating symmetrical input and output.
This A18 entirely designed around discrete component and paired transistors represents a more than serious competitor for all the tenors of this market
Its 100% symmetrical design will allow you to get the most out of your high-end headphones.
Characteristics :
High Performance Canadian Transformer PLITRON
Protections against overheating and overload
Aluminum front 6 mm
Voltage Regulator T03
JFET: K170 / J74
Signal Noise Ratio:> 110 dB
Frequency Response: 20-20KHz-0.1dB
TDH + N: 0.001%
Headphone Output Power: 680 Ohm: 95mW, 300 Ohm: 200mW, 150 Ohm: 400mW, 32Ohm: 1.8W
Dimensions: (250 mm X 180 mm X 55 mm)
Weight: 3kg
Connectors:
Entrance :
Outputs:
1 x 6.35 mm jack
1 x XLR (4-pin) P>
P>
P>
P>
P>
P>
P>
P>
