By buying this product you get 55 loyalty points
High-end headphone amplifier of the brand, integrating symmetrical input and output.
It has been specially developed to be the ideal companion of the brand Saber DA8 converter.
Its 100% symmetrical design will allow you to get the most out of your high-end headphones.
Characteristics :
High Performance Canadian Transformer PLITRON
Protections against overheating and overload
Aluminum front 6 mm
AOP: 2604
Signal Noise Ratio:> 120 dB
Frequency Response: 20-20KHz-0.3dB
TDH + N: 0.0005%
Output power balanced headphone: 680 Ohm: 400mW, 300 Ohm: 700mW, 150 Ohm: 1.3W, 32Ohm: 2.5W
Asymmetric headphone output power: 680 Ohm: 120mW, 300 Ohm: 200mW, 150 Ohm: 350mW, 32Ohm: 800mW
Power consumption: <30W
Dimensions: (250 mm X 200 mm X 55 mm)
Weight: 3kg
Connectors:
Inputs:
1x stereo line onRCA
1x balanced stereo line on XLR
P>
Exits:
2 x 6.35 mm jack
1 x XLR (4-pin) P>
P>
P>
P>
P>
P>
P>
P>
Illustration Yulong Saber DA8 sold separately
P>
