4 channel stereo source selector module
4.0 / 5
Reference : 9950
15,90 €tax incl.
13,25 € tax excl.
This module allows to switch between 4 unbalanced stereo sources.
Delivered with its potentiometer.
Characteristics :
  • Selection by mechanical selector provided
  • Simply requires a 6 to 12V AC transformer
  • No component on signal path except relays
  • Dimensions: 75x42mm
  • Spacing: 67mm, 30mm
  • Weight: 70g
OutputSolder pad
2 reviews
Decent input switching device
The device itself is a very solidly built unit.
Giving only 4 stars because the following:
- the colored cable which connects the rotary switcher to the board has the tendency to break pretty easily. Some heat-shrink tubing would be nice over the connection points.
- for the voltage regulator maybe use an LDO type (eg. KA78R05) or similar for better efficiency (less heat generated)
This review has been posted for 4 channel stereo source selector module
Marche aussi en DC
J'ai acheté le même ailleurs et il marche aussi en DC. Le 12V semble un bon compromis. Dommage qu'il y ai des tic tics d'impulsion qd il n'y a pas de son aux entrées. A part ça, il faut avouer que c'est bien pratique ... Très bon son.
