Source Selector Board 4 Inputs
Input Selector / Volume Control Board 4 Inputs
This source selection module has 4 stereo RCA inputs and one output. A rotary selector is used to select an input / ouput (work both ways). A series of 4 LEDs indicates the active source.
Reference : 15005
28,90 €tax incl.
24,08 € tax excl.
Shipping date: 27-09-2024.
4 Inputs with Light indicators
Module sélecteur de source / contrôle de volume 4 entrées
This source selection module has 4 stereo RCA inputs and one output. It can also work the opposite way : 4 outputs and one input. A rotary selector is used to select the active input/ouptut. A series of 4 LEDs indicates the active source. The module is powered by 12-15VAC.
A Bluetooth receiver module (not included) can be connected via a 3-pin connector. In this case, the 4th RCA input must remain unused.
Product typeInput selection board
Inputs4x Stereo RCA
1x Bluetooth input (optional, Bluetooth module sold separately, replaces 4th RCA input)
Output1x Analog output on 3-pin connector (cable to bare wires included)
Supply voltage12-15VAC on screw terminal (power supply sold separately)
Input/output module dimensions120 x 45mm
Potentiometer module dimensions50 x 30mm
Potentiometer shaft diameterØ6mm (notched)
OutputPCB Connector
Channel2 (Stereo)
This source selection module has 4 stereo RCA inputs and one output. A rotary selector is used to select an input / ouput (work both...
