Has a lot of options, great for the diyer
With LCD screen and remote control
This set of modules, once assembled, allows the creation of a complete volume controller and source selector. It consists of a volume control module, LCD display, input/output module, power supply and remote control.
The whole benefits from a very good manufacturing quality, embedding quality components on double-sided PCBs. The volume control module is notably equipped with a motorized potentiometer ALPS 831M-100KBX4. The display allows it to show the current volume level, the mute mode, as well as the active input and output.
The input/output module consists of 4 stereo inputs and 2 stereo outputs. The associated remote control allows you to switch the module on or off, control the volume level or select an active source.
The power supply module benefits from one AC input and one AC output, making it possible not only to supply all the modules but also to power an amplifier module or external device, while taking advantage of the on/off commands of these modules.
Wiring of these modules requires soldering and the addition of wiring wires (sold separately). RCA sockets can also be added on the inputs and outputs (sold separately).
The remote control uses two AAA batteries (sold separately).
This module includes a volume level memory function, the recorded value being used at each startup. To save a volume value, simply press and hold the "Menu" button (the green LED flashes) then press "Volume -".
Product type | Preamplifier and input selector module |
Inputs | 4x Stereo input |
Outputs | 2x Stereo output |
Screen | LCD 65 x 14mm |
Motorized potentiometer | ALPS 831M-100KBX4 |
AC power | 230V |
Module dimensions | Volume control module: 52 x 60mm Screen: 100 x 45mm Input/Output module: 100 x 55mm Power supply module: 93 x 72mm |
Fixation holes spacing | Volume control module: 46mm Screen: 90 x 35.5mm Input/Output module: 92 x 46mm Power supply module: 85 x 64mm |
Package | 1x Volume control module 1x Screen module 1x Inputs/Outputs module 1x POwer supply module 1x Remote control 1x XH 2.54mm 3 wires cable 1x XH 2.54mm 4 wires cable 1x XH 2.54mm 6 wires cable |
Input | RCA |
Output | RCA |
Color | Gray |
Efficiency / Sensitivity (dB) | 88.0 |
Channel | 2 (Stereo) |
Lowest frequency (Hz) | 46 |
Highest frequency (Hz) | 30000 |
Average votes 5.0 / 5 4 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Patrick d.
David A.
Eloi G.
