Single-Ended to Balanced Converter Module XLR / RCA Mono
This mono single-ended to balanced converter module allows you to retrieve a single-ended signal via its RCA or XLR inputs to output a balanced audio signal on XH2.54mm connector.
Reference : 17314
25,90 €tax incl.
21,58 € tax excl.
Shipping date: 25-04-2025.
Single-ended to Balanced converter
XLR / RCA Mono
Module symétriseur de sources XLR / RCA mono
This mono single-ended to balanced converter module allows you to retrieve a single-ended signal via its RCA or XLR inputs to output a balanced audio signal on XH2.54mm connector. It includes two low noise JRC5532 dual OPAs mounted on DIP8 brackets, which can be easily replaced according to your preferences. In addition, the power supply section of the module includes two Nichicon 2200µF 35V filter capacitors and two L7912CV voltage regulators to provide a clean and stable electrical signal to the other circuits.
Product typeSingle-ended to balanced converter
ChannelsMono (1)
Inputs1* Single-ended mono RCA
1* Single-ended mono XLR
Output1* Balanced mono output on XH2.54mm connector
OPA2* JRC5532
Supply voltage12V-0-12V AC (power supply not included)
Dimensions103*76*25mm
InputXLR
OutputPCB Connector
This mono single-ended to balanced converter module allows you to retrieve a single-ended signal via its RCA or XLR inputs to output a balanced...
