Single-Ended to Balanced Converter Module XLR / RCA Stereo
This stereo single-ended to balanced converter module allows you to retrieve a single-ended signal via its RCA or XLR inputs to output a balanced stereo audio signal on XH2.54mm connectors.
Reference : 17315
39,90 €tax incl.
33,25 € tax excl.
Shipping date: 25-04-2025.
Single-ended to Balanced converter
XLR / RCA Stereo
Module symétriseur de sources XLR / RCA stéréo
This stereo single-ended to balanced converter module allows you to retrieve a single-ended signal via its RCA or XLR inputs to output a stereo balanced audio signal on XH2.54mm connectors. It includes four low noise JRC5532 dual OPAs mounted on DIP8 brackets, which can be easily replaced according to your preferences. In addition, the power supply section of the module includes two rubycon 3300µF 16V filter capacitors and two L7912CV voltage regulators to provide a clean and stable electrical signal to the other circuits.
Product typeSingle-ended to balanced converter
ChannelsStereo (2)
Inputs1* Single-ended stereo RCA
1* Single-ended stereo XLR
Output1* Balanced stereo output on XH2.54mm connectors
OPA4* JRC5532
Supply voltage12V-0-12V AC (power supply not included)
Dimensions161*76*25mm
InputXLR
OutputPCB Connector
This stereo single-ended to balanced converter module allows you to retrieve a single-ended signal via its RCA or XLR inputs to output a balanced...
