Single-Ended to Balanced Converter Module XLR / RCA Stereo
This stereo single-ended to balanced module recovers an unbalanced signal via its RCA inputs on screw terminals, and outputs a balanced stereo audio stream on screw terminals (XLR). Two TI NE5532P balancer OPAs handle audio signal processing. DIP8-mounted, they are easily replaceable according to your preferences.
Reference : 18248
12,90 €tax incl.
10,75 € tax excl.
Shipping date: 22-04-2025.
This stereo single-ended to balanced module recovers a single-ended signal via its inputs on screw terminals, and outputs a balanced stereo audio stream also on screw terminals. Two TI NE5532P balancer OPAs handle audio signal processing. DIP8-mounted, they are easily replaceable according to your preferences. On the power supply side, this module integrates two Nichicon 4700uf 35V capacitors and two L7912CT linear voltage regulators to provide the PCB circuit with a clean, stable electrical signal. A screw terminal block allows this module to be supplied with 2x15VAC and a minimum of 200mA. A stereo XLR input is also present, with a bypass function and a switch button for selecting the input source via two EA2-5 NEC relays.
Single-ended RCA to balanced XLR and XLR-to-XLR bypass
1Power supply: +15V AC
2Power supply: GND
3Power supply: -15V AC
4Left channel RCA input: Hot spot (+)
5Left channel RCA input: GND
6Right channel RCA input: GND
7Left channel RCA input: Hot spot (+)
8Left channel XLR input: Cold point (-)
9Left channel XLR input: GND
10Left channel XLR input: Hot spot (+)
11Right channel XLR input: Cold point (-)
12Right channel XLR input: GND
13Right channel XLR input: Hot spot (+)
14Left channel XLR output: Cold point (-)
15Left channel XLR output: GND
16Left channel XLR output: Hot spot (+)
17Right channel XLR output: Cold point (-)
18Right channel XLR output: GND
19Right channel XLR output: hot spot (+)
20Switching button/Source selection
21Capacitors
22L7912CT voltage regulators
23OPA NE5532P
24EA2-5 relays
Product typeSingle-ended to balanced module
ChannelsStereo
Inputs1* Stereo single-ended (screw terminals)
1* Stereo balanced (screw terminals)
Output1* Stereo balanced (screw terminals)
OPANE5532P
Power supply2x15VAC 200mA (12V-18V)
Dimensions100*55mm
Weight86g
Package1* Single-Ended to Balanced Converter Module XLR / RCA Stereo
InputScrew terminals
OutputScrew terminals
Consommation de ce module
Bonjour,
Vous annoncez une consommation de 200 mA pour ce module équipés de deux NE5532 !
Ca ne serait pas plutôt 20 mA ?
Je comptais faire l'acquisition de 2 de ces modules et les alimenter à partir des tensions annexes fournies par une alimentation SMPS300RE, soit une consommation de 400 mA ce qui me semble donc beaucoup.
Cordialement
This review has been posted for Single-Ended to Balanced Converter Module XLR / RCA Stereo
This stereo single-ended to balanced module recovers an unbalanced signal via its RCA inputs on screw...
