MUNDORF N300 Zero Ohm Self Coil 3mH
Self Mundorf Zero Ohm Coil ZOC N300 3.0mH
The Zero Ohm Coil (ZOC) is a transformer sized coil. It is made of Feron, a high quality material that limits the induced distortion to a maximum. In the ZOC, the center space is calibrated and adjusted by hand between the two laminar cores.
Reference : 1700
149,00 €tax incl.
124,17 € tax excl.
Mundorf N300
Self Zero Ohm Coil 3mH
Mundorf N300 Self Bobine Zéro Ohm
The Zero Ohm Coil (ZOC) is a transformer sized coil. It is made of Feron, a high quality material that limits the induced distortion to a maximum. In the ZOC, the center space is calibrated and adjusted by hand between the two laminar cores (one L-shaped, one E-shaped). The volume of the center gap determines the inductance of the coil and requires great care in the manufacturing process. It must not be too thin, otherwise saturation effects could occur at high load. These coils are recommended for filtering bass speakers. Their low impedance allows to improve the impulse response (better speaker behaviour).
Product typeZero Ohm Coil
ToleranceMax. 5%
CoreFeron
Conductor materialOFC Copper (purity : 99.99%)
Inductance3mH
Dimensions106 x 94 x 88mm
Inductance (mh)3.0
The Zero Ohm Coil (ZOC) is a transformer sized coil. It is made of Feron, a high quality material that limits the induced distortion to a maximum....
