MUNDORF VN300 Zero Ohm Self Coil 1.5mH
The Zero Ohm Coil (ZOC) is a transformer format coil. It is made of Feron, a material with high electronic qualities that minimizes induced distortions.
By buying this product you get 23 loyalty points
Reference : 18899
239,00 €tax incl.
199,17 € tax excl.
Photo de la bobine Mundorf VN300 zéro ohm 1.5mH
The central spot of a ZOC is calibrated and adjusted by hand between two laminar rings (a L-shaped and a E-shaped). The volume of the central space determines the inductance of the coil which demands enormous precision in the manufacturing process to ensure there will be no saturation at high load.
These coils are especially suitable for filtering your bass speakers. Their low impedance improves the impulse response.
Product typeZero Ohm coil
Conductor materialPure OFC Copper
NoyauFeron
Inductance1.5mH (+/- 5%)
Resistance DC0.02 Ohm
Wire cross-section3mm (AWG9 - 7.07mm²)
Winding fixationResin
Coil body typeN96
Dimensions96 x 86 x 84mm
Package1x MUNDORF VN300 Zero Ohm Self Coil 1.5mH
Inductance (mh)1.5
The Zero Ohm Coil (ZOC) is a transformer format coil. It is made of Feron, a material with high electronic qualities that minimizes induced...
