MUNDORF VN390 Zero Ohm Self Coil 1.5mH
MUNDORF VN390 Self Bobine Zéro Ohm 1.5mH
The Mundorf VN390 Zero Ohm Coil (ZOC) is a transformer format coil. It is made of Feron, a material with high electronic qualities that minimizes induced distortions.
Reference : 18127
219,00 €tax incl.
182,50 € tax excl.
MUNDORF VN390
Mundorf Self Bass Woofer Sub
The central spot of a ZOC is calibrated and adjusted by hand between two laminar rings (a L-shaped and a E-shaped). The volume of the central space determines the inductance of the coil which demands enormous precision in the manufacturing process to ensure there will be no saturation at high load.
These coils are especially suitable for filtering your bass speakers. Their low impedance improves the impulse response.
Product typeSelf Coil
Inductivity1.5mH ±5%
DC resistance0.02 Ohm
Conductor Cross section11,95mm² (AWG 6.5 /3.90mm)
Coil coreZERO-OHM
Conductor materialOFC copper
Coil body typeN106
Winding FixationResin-soaked
Dimensions106 x 93 x 87mm (LxHxZ)
Package1x MUNDORF VN390 self coil
Inductance (mh)1.5
The Mundorf VN390 Zero Ohm Coil (ZOC) is a transformer format coil. It is made of Feron, a material with high electronic...
