IAN CANADA PUREPI Ultracapacitor / Batteries Dual Power Supply Module for Raspberry Pi 5V / 3.3V
Ian Canada's PurePi is a compact audiophile power supply module specifically designed for Raspberry Pi based systems to improve sound quality. The PurePi integrates a 5V supercapacitor power supply and a second isolated 3.3V LifePO4 battery rail. Thanks to the use of spring contacts, it is very easy to install a Raspberry Pi or other audio HAT on top of the PurePi, without the need for an additional power supply connector.
Reference : 16684
115,00 €tax incl.
95,83 € tax excl.
This product has been replaced by the new version, the IAN CANADA PUREPI II Ultracapacitor / Batteries Dual Power Supply Module.
Ian Canada PurePi
Ian Canada PurePi Module d'Alimentation Double à Supercondensateur / Batteries pour Raspberry Pi 5V / 3.3V
The PurePi is from a functional point of view equivalent to a ConditionerPi 5V associated with a LifePO4Mini 3.3V.
Key features:
  • 5V supercapacitor power supply with two 100F-2.7V supercapacitors pre-installed. ESR less than 10mΩ.
  • Isolated 3.3V power supply on LifePO4 battery, with pre-installed battery cradle for two 18650 cells. ESR below 6mΩ.
  • Gold-plated spring contacts to power a Raspberry Pi directly via the GPIO, without adding a connector.
  • Works as a stand for a complete audio project. Spikes can be installed, as well as rubber rings, to limit vibrations.
  • Only a 5V 2.5A power supply required as input, via USB-C.
  • Integrated ON/OFF button. Can be deported to have an external switch.
  • ON/OFF control signal for integration into a multi-power supply system as a master ON/OFF control.
  • Integrated protection system to prevent battery wear and maintain an adequate electrical signal.
  • Ultra-low noise and high dynamic range passive power supply.
  • Ultra low ESR MOSFETs controlled by optical isolators to eliminate current leakage.
Product typePower supply module for Raspberry Pi
Input voltage5V 2.5A
Output voltageUltracapacitor power supply: 5V
Batteries power supply: 3.3V
Dimensions141 x 108mm
Mouting holes spacing127 x 94mm
InputScrew terminals
OutputPCB Connector
2 reviews
Indispensable
Je voulais voir à quoi ça rimait cette débauche de cartes d'alimentations à base de supercondensateurs et batterie LifePo4 sur ce site. Pour satisfaire ma fringale, j'ai donc commencé par celle-ci et bien ! je ne suis pas déçu mais enthousiasmé, l’installation de cette petite carte électronique sur un Rapsberry pi 3 c'est la "cerise sur le gateau"
La petite framboise s'est transformé en une bête de course musicale, rien que ça. Bravo Ian Canada et Audiophonics. A mon avis, une réussite, et un accessoire indispensable.
This review has been posted for IAN CANADA PUREPI Ultracapacitor / Batteries Dual Power Supply Module for Raspberry Pi 5V / 3.3V
and another great product from ian canada.
installation is very simple and works fine with a raspberry pi.
also purchased a fifoPIMa 1.5 and works nicely with this power supply.
Ian Canada's PurePi is a compact audiophile power supply module specifically designed for Raspberry Pi based systems to improve sound quality....
