RASPBERRY PI 5 4Gb Micro HDMI Ethernet Gigabit WiFi Bluetooth 5.0 4x USB 2.4GHz
The latest addition to the SBC Raspberry Pi range, the Raspberry PI 5 4Gb offers a number of improvements over its predecessor, the Rasberry Pi 4. Overall performance is two to three times better than its predecessor, and graphics rendering has been greatly enhanced. This model uses the same basic features that made the Raspberry 4 such a success, but with completely redesigned connectors.
Reference : 18332
89,00 €tax incl.
74,17 € tax excl.
Shipping date: 18-04-2025.
RASPBERRY PI 5 4Gb
The main improvements on the Rasberry Pi 5 are a BCM2712 system-on-a-chip (SoC) with a new quad-core ARM A76 processor (ARM v8 - 64-bit - 2.4GHz) and a Video Core VII GPU for exceptional graphics performance. It is able to stream 4K 60fps video to two screens simultaneously via its micro-HDMI ports and supports HDR. In terms of connectivity, it now features a PCIe 2.0 FPC connection, as well as an RTC connector for real-time clocking and a UART port for debugging. A power ON/OFF switch has been added to the PCB for greater convenience.
It also retains the features of its predecessor, such as its LPDDR4 RAM, 2.4/5.0GHz wireless networking, Bluetooth 5.0 (BLE), Gigabit Ethernet, USB 3.0 and PoE (the PoE HAT module is sold separately).
Please note, however, that the latest version of the operating system (Bookworm) is recommended to take full advantage of the Raspberry Pi 5's capabilities. The Pi 5's power supply is now a USB-C 5V 5A port, so we also recommend using the new Raspberry Pi 27W USB power supply.
Older Raspberry HAT PoE and PoE+ are no longer compatible with the PI5 version due to the new connector layout.
An optimized all-in-one computer
After 7 years of development, the RP1 chip has been integrated into the Raspberry Pi 5 for greatly optimized I/O performance. It's thanks to the integration of this component that the Raspberry Pi 5 offers overall performance 2 to 3 times better than its predecessor. Whether used as a multimedia server, audio player, programming tool or even for browsing the Internet with numerous tabs open, navigation will remain fluid for an unprecedented user experience for this type of device.
A high-performance chipset
BCM2712
At its heart is a 64-bit, quad-core Arm Cortex-A76 processor, running at 2.4 GHz, with 512 KB of L2 cache per core and a shared 2 MB L3 cache. It allows more instructions per clock (IPC) and less energy per instruction. The Raspberry Pi 5 is therefore faster and consumes less energy.
RP1
As the Raspberry Pi 5's I/O controller, it enables fast execution. Designed to be functionally very similar to the BCM2711, it guarantees a high degree of compatibility with older Raspberry Pi devices.
DA9091
The Renesas DA9091 power management IC integrates 8 separate switched-mode power supplies to generate the different voltages required by the Raspberry Pi 5, in particular to power the BM2712 and the RP1.
Raspberry Pi 5 overview
1Brodcom BCM2712
2RP1
3DA9091
4ON/OFF switch
52-pin JST connector for RTC battery
6USB-C power port 5V 5A
81x HDMI micro output
93-pin JST Debog/UART connector
101x HDMI micro output
11Pads connectors (composite video)
124-way MIPI DSI / CSI connectors (FPC)
134-pin PoE connector
14Ethernet RJ45 port
152x USB 3.0 ports
162x USB 2.0 ports
174-pin JST connector for fan with PWM control and tachogenerator feedback
1840-pin GPIO
19PCIe 2.0 connector
Differences between the Raspberry Pi 5 and the Raspberry Pi 4 (model B)
Raspberry Pi 5
RaspBerry Pi 4 model B
Architecture
64Bits
64Bits
SoC
Broadcom BCM2712
Broadcom BCM2711
CPU
2,4 GHz quad-core ARM Cortex-A76
1,5 GHz quad-core ARM Cortex-A72
GPU
VideoCore VII - 800 MHz
OpenGL ES 3.1, Vulkan 1.2
Broadcom VideoCore VI - 500 MHz
OpenGL ES 3.0
Memory (SDRAM)
4Go
2Go
USB ports
2x 2.0 / 2x 3.0 - up to 5Gbps simultaneously
2 x 2.0 / 2 x3.0 - up to 5Gbps
Video outputs
2x Micro-HDMI (4K - 60 FPS simultaneously)
2x Micro HDMI and Composite
(4K - 60 FPS up to 1080p simultaneously)
Audio ouputs
5.1 on micro-HDMI
3.5 mm stereo jack
5.1 on micro-HDMI
Memory (Storage)
Micro-SD
(high-speed transfer - SDR104 mode)
Micro-SD
Ethernet (RJ45)
10/100/1000 Ethernet
Wi-Fi
Dual-band 802.11ac
Dual-band 802.11ac
Bluetooth
5.0 / BLE
5.0 / BLE
GPIO
17 × GPIO, UART, I²C bus, SPI bus with two chip selects, I²S audio, +3.3 V, +5 V98
17 × GPIO, UART, I²C bus, SPI bus avec deux chip selects, I²S audio, +3.3 V, +5 V98
Video / Audio interfaces
2 DSI / CSI (MIPI)
2 DSI (MIPI) 2 CSI (MIPI)
Stereo audio / composite video port (4-pin)
RTC
RTC connectors
Power-on
Switch ON/OFF
Immediately after power-up
Power supply
5V / 5A
5V / 3A
Dimensions
86 mm × 56 mm × 16 mm
85 mm × 56 mm × 16 mm
Weight
46g
46g
Product typeSBC (Single Board Computer)
ProcessorBroadcom BCM2712, Quad Core Cortex-A76 (ARM v8) 64bit SoC @ 2.4GHz
RAM Memory4Gb LPDDR4X-4267
Connectors2x Micro-HDMI ports
1x Micro-SD port
2x USB 3.0 ports
2x USB 2.0 ports
1x 40-pin GPIO connector
1x 16-pin 0.50 mm connector with PCIe 2.0 FFC interface
1x RJ45 Ethernet port
2x 4-way MIPI DSI (display) / CSI (camera) connectors
1x RTC connector for official real-time clock
1x Fan connectors
1x USB-C (Power supply)
NetworksWi-Fi 802.11ac dual bande
Bluetooth 5.0 / Bluetooth Low Energy (BLE)
Supported codecsH.265 (4Kp60)
H.264 (1080p60, 1080p30)
OpenGL ES 3.1 / Vulkan 1.2
PoE Compatibility (Power Over Ethernet)Requires PoE HAT (not supplied)
Power supply5V DC via USB-C (minimum 5A)
5V DC via GPIO (minimum 5A)
Dimensions86 × 56 × 16mm
Distance between fixation holes58 x 49mm
Weight46g
Package1x Raspberry Pi 5
InputRJ45
InputGPIO
InputMicro SD
InputWiFi
OutputUSB
OutputBluetooth
OutputMicro HDMI
OutputGPIO
OutputWiFi
The latest addition to the SBC Raspberry Pi range, the Raspberry PI 5 4Gb offers a number of improvements over its predecessor, the Rasberry Pi 4....
