CONNEX SMPS2000RS Switching Mode Power Supply Module 2000W +36V
The SMPS2000RxE power supply is a very high efficiency model capable of developing a nominal power of 2000W in an extremely small footprint. This power supply is capable of delivering 2000W of continuous power and up to 2600W of peak power with a suitable heat sink.
By buying this product you get 26 loyalty points
Reference : 13662
269,00 €tax incl.
224,17 € tax excl.
Shipping date: 24-04-2025.
SMPS2000RS
Switching Mode Power Supply Module 2000W 36V
Connex SMPS2000RxE Module d'Alimentation à Découpage 2000W 36V
The SMPS2000RS power supply is a very high efficiency model capable of developing a nominal power of 2000W in an extremely small footprint. This power supply is capable of delivering 2000W of continuous power and up to 2600W of peak power with a suitable heat sink. The delivered version has an output voltage of +36V.
The main feature of this power supply is the absence of radiators for both power switches and rectifier diodes. EMI (electromagnetic interference) is less than for any conventional power supply and could be compared to a regulated linear power supply.
Its small size and considerably reduced weight make it possible to install the SMPS2000RS almost anywhere. In addition, this power supply incorporates overcurrent protection that limits the output current to approximately 130% of the maximum peak power, or approximately 2600W. This power supply is suitable for both Class AB and Class D/T amplifiers.
Meaning of the terms R, RE, RS and RxE for SMPS power supplies :
  • QR, R : SINGLE or DUAL power supplies with classic LLC resonance filter for Class AB or D amplifiers. SMPS R are characterized by their good quality/price ratio.
  • RE : SMPS power supplies with differential outputs and multiple resonance filter voltages, including an LLC filter with low noise EMI filter (and CLC filter at low ripple output) for high-end amplifiers in Class AB or D/T. Replaces conventional linear power supplies (generally suitable for amplifiers TA2022, TDA8920, TDA8950, IRS2092...).
  • RS : SMPS power supplies close to RE but with Single Rail Output resonant filter, including an LLC filter with low noise EMI filter (and CLC filter at low ripple output) for high-end amplifiers in Class AB or D/T. Replaces conventional linear power supplies advantageously.
  • RxE : The high-end SMPS 600W, 800W and 2000W featuring the latest generation LLC resonant filters (with CLC filter at low ripple output) with high-end FET transistors. Specially recommended for Class D high end amplifiers (IRS2092, Hypex, CXD...). Can also be used for conventional Class AB amplifiers.
Product typeSwitching Mode Power Supply (SMPS)
Output voltage36V
Power2000W
Peak power with heatsink2600W
EfficiencyApprox. 95%
Aux output+/-12V or 15V 500mA
Supported current30A (40A peak)
Dimensions120 x 200 x 40mm
WeightApprox. 900g
Supply voltage230V AC
InputPCB Connector
OutputPCB Connector
Output voltage (V)36.0
Output current (A)15.0
Input voltage (V)230.0
Input voltage (V)120.0
Power SupplySMPS
The SMPS2000RxE power supply is a very high efficiency model capable of developing a nominal power of 2000W in an extremely small footprint. This...
