CONNEX SMPS2000RxE Switched mode Power supply module 2000W / 40V
Reference : 11499
299,00 €tax incl.
249,17 € tax excl.
Shipping date: 18-04-2025.
The SMPS2000RxE switching power supply is a very high efficiency model capable of developing a nominal power of 2000 Watts in an extremely small footprint.
This power supply is capable of delivering 2000W of continuous power and up to 2600W in peak with a suitable heat sink.
The delivered version is a 40 V.
The main feature of this power supply is the lack of radiators for both power switches and rectifier diodes.
The amount of EMI is less than any conventional power supply, and could be compared to a linear regulated power supply.
Its small size and considerably reduced weight allow the SMPS2000R to be installed almost anywhere.
The SMPS2000RxE incorporates overcurrent protection that limits the output current to approximately 130% of maximum peak power, or about 2600W.
This power supply is suitable for both class AB and class D / T amplifiers.
Data sheet / Datasheet (Click here)
Meaning of terms R, RE, RS and RXE on SMPS power supplies:
QR, R: SINGLE or DUAL power supplies with classical resonance filter LLC for amplifiers in class A / B or D, SMPS R are characterized by their ratio qualities price.
RE: SMPS power supplies with differential and multiple voltage outputs with resonant filter including an LLC filter with low noise EMI filter (with low ripple CLC filter) for class A / B or D / T class Amplifiers. Conveniently replaces conventional linear power supplies. (Generally suitable for TA2022, TDA8920, TDA8950, IRS2092 amplifiers)
RS: SMPS power supplies close to the RE but with a single rail output with a resonant filter including an LLC filter with low noise EMI filter (with low ripple CLC filter) for class A / B or D / T amplifiers . Advantageously replaces conventional linear power supplies.
RXE: The high-end SMPS 600, 800W and 2000W featuring the latest generation LLC resonant filters (with low-ripple CLC filter) with high-end FET transistors. Especially recommended for Class D high-end amplifiers (IRS2092, HYPEX, CXD). Can also be used for class A / B amplifiers.
Caracharacteristics:
  • High efficiency feed
  • Choice of input voltage
  • Stunning Compactness
  • Low electromagnetic radiation (EMI)
  • Advanced Protection
  • Output voltage 40V
  • Auxiliary output +/- 12V or 15V 500mA
  • Supported DC current: 30A continuous max and 40A peak
  • Rated Power: 1200W
  • Maximum power: 1600W
  • Dimensions: 120x200x40mm
  • Weight: 900g
Specifications:
  • Input Voltage: 190-250V (On Sector 220V)
  • Output Voltage: (40V)
  • Maximum Power: 2600W (with suitable heatsink)
  • Nominal Power: 2000 W
InputPCB Connector
OutputPCB Connector
Output voltage (V)15.0
Output voltage (V)40.0
Output voltage (V)12.0
Output current (A)NC
Input voltage (V)250.0
Input voltage (V)230.0
Input voltage (V)220.0
Input voltage (V)190.0
Power SupplySMPS
Download
