Switched Mode Power Supply Module 2000W +/-92V
The SMPS2000RxE is a very high efficiency power supply capable of delivering 2000 Watts of rated power in an extremely small footprint. This power supply is capable of delivering 2000W of continuous power and up to 2600W peak power with a suitable heat sink. It can be configured for dual output voltage from +/-40V to +/-180V (on request). The version delivered is +/-92V.
The available output voltages are adjustable by about 10%. The main feature of this power supply is the absence of heat sinks for both the power switches and the rectifier diodes. The amount of EMI is lower than any conventional power supply, and could be compared to a linear regulated power supply.
Its small size and considerably reduced weight allow the SMPS2000R to be installed almost anywhere. The SMPS2000RxE incorporates overcurrent protection that limits the output current to approximately 130% of the maximum peak power, or about 2600W. This power supply is suitable for both class AB and class D/T amplifiers.
QR, R : SINGLE or DUAL power supplies with classic LLC resonance filter for class A/B or D amplifiers, the SMPS R are characterized by their price/performance ratio.
RE : SMPS power supplies with differential and multiple voltage resonant filter outputs featuring a low noise EMI filter (with CLC filter on low ripple output) for high end class A/B or D/T amplifiers. It is a good alternative to conventional linear power supplies (usually suitable for TA2022, TDA8920, TDA8950, IRS2092 amplifiers).
RS : SMPS power supplies similar to RE but with "Single Rail Output" with resonant filter including LLC filter with low noise EMI filter (with CLC filter in low ripple output) for high end amplifiers in class A/B or D/T. Replaces conventional linear power supplies.
RxE : The top of the line SMPS 600, 800W and 2000W featuring the latest generation of LLC resonant filters (with low ripple output CLC filter) with high end FET transistors. Especially recommended for high end class D amplifiers (IRS2092, HYPEX, CXD). Can also be used for classic class A/B amplifiers.
Product type | Switched mode power supply |
Power | 2000W |
Main output voltage | ±92V (min. ±88V / max. ±96V) |
Aux output voltage | Min. ±16.5V Max. ±20V |
Input voltage | 196-254V |
Main output current | Nominal : 10.8A Peak : 14.3A |
Aux output current | Nominal : 0.2A Peak : 0.5A |
Efficiency @ 40-60% de charge | 120V: 95.4% 230V: 96.1% |
Dimensions | 200 x 120 x 42mm |
Weight | 880g |
Input | PCB Connector |
Output | PCB Connector |
Output voltage (V) | 16.5 |
Output voltage (V) | 92.0 |
Output voltage (V) | 20.0 |
Output current (A) | NC |
Input voltage (V) | 100.0 |
Input voltage (V) | 125.0 |
Input voltage (V) | 120.0 |
Input voltage (V) | 200.0 |
Input voltage (V) | 250.0 |
Input voltage (V) | 110.0 |
Input voltage (V) | 230.0 |
Input voltage (V) | 220.0 |
Power Supply | SMPS |
