Switching Mode Power Supply Module 2000W +/-70V
The SMPS2000RXE power supply is a very high efficiency model capable of developing a nominal power of 2000W in an extremely small footprint. This power supply is capable of delivering 2000W of continuous power and up to 2400W of peak power with a suitable heat sink. The delivered version has an output voltage of +/-70V.
The main feature of this power supply is the absence of radiators for both power switches and rectifier diodes. EMI (electromagnetic interference) is less than for any conventional power supply and could be compared to a regulated linear power supply.
Its small size and considerably reduced weight make it possible to install the SMPS2000RXE almost anywhere. In addition, this power supply incorporates overcurrent protection that limits the output current to approximately 130% of the maximum peak power, or approximately 2400W. This power supply is suitable for both Class AB and Class D/T amplifiers.
Product type | Switching Mode Power Supply (SMPS) |
Output voltage | 70V |
Power | 2000W |
Peak power with heatsink | 2400W |
Efficiency | Approx. 95% |
Aux output | +/-12V or 15V 500mA |
Supported current | 27A (32A peak) |
Général | |
Dimensions | 120 x 200 x 40mm |
Weight | Approx. 900g |
Supply voltage | 230V AC |
Input | PCB Connector |
Output | PCB Connector |
Output voltage (V) | 15.0 |
Output voltage (V) | 12.0 |
Output current (A) | NC |
Input voltage (V) | 230.0 |
Input voltage (V) | 220.0 |
Power Supply | SMPS |
