CONNEX SMPS300RE Switched-Mode Power Supply Module US Version 300W +/-24V 120V
L'alimentation à découpage SMPS300RE est un modèle à très haut rendement capable de développer une puissance nominale de 300W pour un encombrement réduit. Celle-ci pourra donc délivrer 300W de puissance en continue et jusqu'à 400W en crête. Le modèle livré est une version US prenant en entrée une tension de 120V et délivrant en sortie +-24V.
Reference : 12848
85,00 €tax incl.
70,83 € tax excl.
Connex SMPS300RE
Switched-Mode Power Supply Module US 120V 300W +-24V
Connex SMPS300RE Module d'Alimentation à Découpage 300W +-24V
The SMPS300RE switching power supply is a very high efficiency model capable of developing a rated power of 300W for a reduced space requirement. It will therefore be able to deliver 300W of continuous power and up to 400W of peak power. The model delivered is a US version taking an input voltage of 120V and outputting +-24V.
The main feature of this power supply is the absence of radiators for both power switches and rectifier diodes. The amount of EMI is less than on any conventional power supply and could be compared to a regulated linear power supply. The SMPS300RE can be installed in many enclosures due to its small size and considerably reduced weight.
In addition, the module incorporates overcurrent protection that limits the output current to about 130% of the maximum peak power, or about 400W. This power supply is suitable for both Class AB and Class D/T amplifiers.
Attention: This is a US version with an input voltage of 120V. Never use on a 230V European electrical system.
Meanings of the abbreviations on the SMPS power supplies
QR, R : SINGLE or DUAL power supplies with classical LLC resonance filter for Class AB or D amplifiers. SMPS R are characterized by their very good price/quality ratio.
RE : SMPS power supplies with differential outputs and multiple resonance filter voltages, including an LLC filter with low noise EMI filter (with CLC filter at low ripple output). Suitable for high-end amplifiers in Class AB, D or T. Replaces conventional linear power supplies advantageously. (Generally suitable for TA2022, TDA8920, TDA8950, IRS2092 amplifiers).
RS : SMPS power supplies close to RE but with Single Rail Output resonant filter including LLC filter with low noise EMI filter (with CLC filter at low ripple output). Suitable for high-end amplifiers in Class AB, D or T. Replaces conventional linear power supplies advantageously.
RXE : The high-end SMPS 600W, 800W and 2000W featuring the latest generation LLC resonant filters (with CLC filter at low ripple output) with high-end FET transistors. Specially recommended for high-end Class D amplifiers (IRS2092, Hypex, CXD). Can also be used with Class AB amplifiers.
Power supply typeSwitched-Mode Power Supply
Output voltage+-24V
Input voltage120V
Auxiliary output+-19V
Very high efficiency power supply-
Low electromagnetic radiation EMI-
Advanced protection system-
Max power400W
Rated power300W
Dimensions100 x 100 x 40mm
WeightApprox. 360g
InputPCB Connector
OutputScrew terminals
Output voltage (V)24.0
Output voltage (V)15.0
Output current (A)NC
Input voltage (V)120.0
Power SupplySMPS
L'alimentation à découpage SMPS300RE est un modèle à très haut rendement capable de...
