HYPEX PS500DIY Switching Mode Power Supply Module 600W +/-70V
This PS500DIY switching power supply module has been designed by Hypex specifically to power its Nilai500DIY amplifier modules. With its 600W power and +/-70V output, it can power one or two Nilai500DIY modules simultaneously.
Reference : 17998
299,00 €tax incl.
249,17 € tax excl.
Shipping date: 22-04-2025.
HYPEX PS500DIY
HYPEX PS500DIY Module d'Alimentation à Découpage SMPS 600W 2x70V
This PS500DIY switching power supply module has been designed by Hypex specifically to power its Nilai500DIY amplifier modules. With its 600W power supply and +/-70V output, it can power one or two Nilai500DIY modules simultaneously. This power supply uses audiophile-grade components and a PFC (Power Factor Correction) for increased power density and reduced conductivity of EMI interference. Protected against overcurrents, the Hypex PS500DIY power supply is highly reliable. What's more, it is designed for universal use, accepting inputs from 100 to 240VAC (+/- 10%). As for the connectors, there are Molex connectors for the outputs used to power the amplifier module(s) such as the Nilai500DIY, as well as I/O and HBUS connectors for controlling the PS500DIY module and connecting third-party electronic components. The PS500DIY power supply is therefore an excellent choice for all DIY projects requiring a clean, powerful power supply.
Connectors of the Hypex PS500DIY power supply module
1AC input
2HBUS output PCB connector
3+/-70VDC Molex output
4+/-70VDC Molex output
5I/O PCB connector
Product typeSwitching mode power supply module
Input voltage arnge100-240VAC +/-10%
Fuse: 250VAC 6.3A (Warning: the fuse is soldered to the printed circuit board and cannot be replaced.)
Main output voltages2x ±70V
Output power600W
Max. output power800W
Standby supply output5V 1A
Auxiliary supply output±18V / 200mA
Standby power0.2W
Idle power5.5W
Dimensions100*170*47mm
WeightApprox. 900g
Package1x Hypex PS500DIY module
2x Cable asm Z14A30L2 (30cm amplifier connection cable)
1x Cable asm Z12C30L1 (30cm auxiliaries’ cable)
1x Cable asm Z2B30L3 (30cm power input cable)
1x PS500DIY mounting set
1x PS500DIY manual
InputPCB Connector
OutputMolex
Output voltage (V)70.0
Output current (A)6.0
Input voltage (V)240.0
Input voltage (V)100.0
Input voltage (V)230.0
Input voltage (V)90.0
Input voltage (V)200.0
Input voltage (V)220.0
Input voltage (V)250.0
Input voltage (V)120.0
Input voltage (V)130.0
Input voltage (V)190.0
Input voltage (V)150.0
Input voltage (V)210.0
Power SupplySMPS
This PS500DIY switching power supply module has been designed by Hypex specifically to power its Nilai500DIY amplifier...
