HYPEX SMPS1200A100 Switching Power Supply Module 1200W 2x36V
The Hypex SMPS1200A180 is a high performance Class 2 switched mode power supply, originally designed for UcD / NCore amplifier modules. Capable of delivering 2x36VDC at 1500W, this power supply has excellent efficiency over the entire load range and excellent resistance to EMI interference in a compact and lightweight package. It also incorporates an effective overcurrent protection system.
Reference : 14847
215,00 €tax incl.
179,17 € tax excl.
Hypex SMPS1200A180
Hypex SMPS1200A180 Module d'alimentation à découpage 1200W 2x46V
Buffer electrolytic capacitors provide a comfortable headroom for the connected amplifier. The module also has a 2x 20VDC balanced auxiliary output and a control circuit that can interface directly with UcD / NCore amplifiers.
The Hypex SMPS1200 power supplies are ideal for integration into a High Fidelity audio system.
Diagram viewed from below
Rear diagram
Product typeSwitching power supply module
Input voltage230VAC / 115VAC (with jumper)
Output voltage2x 36VDC
Aux output2x 20VDC 500mA
Max. output power1500W
1200W @ 20Hz
Dimensions165 x 105 x 55mm
Weight750g
Output voltage (V)2x36
Input voltage (V)115.0
Input voltage (V)230.0
Power SupplySMPS
The Hypex SMPS1200A180 is a high performance Class 2 switched mode power supply, originally designed for UcD / NCore amplifier modules. Capable of...
