HYPEX SMPS1200A180 Switching Power Supply Module 1200W 2x46V
The Hypex SMPS1200A180 is a high performance Class 2 switched mode power supply, originally designed for UcD / NCore amplifier modules. Capable of delivering 2x46VDC at 1500W, this power supply has excellent efficiency over the entire load range and excellent resistance to EMI interference in a compact and lightweight package. It also incorporates an effective overcurrent protection system.
By buying this product you get 22 loyalty points
Reference : 14418
229,00 €tax incl.
190,83 € tax excl.
Shipping date: 22-04-2025.
Hypex SMPS1200A180
Hypex SMPS1200A180 Module d'alimentation à découpage 1200W 2x46V
Buffer electrolytic capacitors provide a comfortable headroom for the connected amplifier. The module also has a 2x 22VDC balanced auxiliary output and a control circuit that can interface directly with UcD / NCore amplifiers.
The Hypex SMPS1200 power supplies are ideal for integration into a High Fidelity audio system.
Diagram viewed from below
Rear diagram
Product typeSwitching power supply module
Input voltage230VAC / 115VAC (with jumper)
Output voltage2x 46VDC
Aux output2x 22VDC 500mA
Max. output power1500W
1200W @ 20Hz
Dimensions165 x 105 x 55mm
Weight750g
InputPCB Connector
OutputPCB Connector
Output voltage (V)46.0
Output current (A)NC
Input voltage (V)115.0
Input voltage (V)230.0
Power SupplySMPS
Bonnne alimentation
Utilisé pour alimenter des modules classe AB. Fait bien le job pour un poids très contenu.
This review has been posted for HYPEX SMPS1200A180 Switching Power Supply Module 1200W 2x46V
The Hypex SMPS1200A180 is a high performance Class 2 switched mode power supply, originally designed for UcD / NCore amplifier modules. Capable of...
